S32DS startup issue
S32DS startup issue
988件の閲覧回数
Dan0408
When I started S32DS V3.5 (installed with valid license), there's a popup window named "Product Licenses" showing the detail infos "...\S32DS\cll\x64\FNP_Act_Installer.dll: 动态链接库(DLL)初始化例程失败。"  and closing the window also quits the IDE.  Reinstalling the IDE doesn't work.
2 返答(返信)
919件の閲覧回数
jiri_kral
looks that some security SW on your PC may block the .dll used for license check. Can you please share workspace log file located in your workspace and .metadata directory?
863件の閲覧回数
Dan0408
It seems that this problem no longer occurs after a system reboot. Thanks for your kind reply
