Select the "S32 Configuration Tool" menu then click on the desired configuration tool (Pins, Cocks, Peripherals etc...).
Clicking on any one of those will generate all the components. Make the desired changes(if any) then click on the "S32 Configuration Tool->Update Code" button.
Do you still encounter errors when you build after clicking Update Code?
I refer to HOWTO: offline install S32K3 RTD 3.0.0 in S32DS v3.5 to install S32K3, and then install SW32K3_FreeRTOS_10_5_1_UOS_3_1_0_DS_updatesite_D2304.zip. No errors will be encountered when building.
Sorry, I haven't seen the S32K312 examples since the version after S32K3 RTD 2.0.3. As you know, S32K3 has many derivatives, so to reduce effort, in the most recent RTD releases we only provide examples for K344, K358, and K396.
Robin
Robin
