S32DS IDE,in Configtool getting a Warning - LPUART driver not found in the toolchain/IDE project
Bharath_S
In S32DS IDE,under Configtool getting a Warning - LPUART driver not found in the toolchain/IDE project
How to resolve the issue.
Bharath
PetrS
if you Select component it will be added to project then. And you can check via Manage SDK components button, if driver is finally added.
BR, Petr
