S32DS ARM
S32DS ARM
2,296件の閲覧回数
VanNgo285
I just installed S32DS ARM. I open my project but project's SDKs seem like wrong.
How to fix this issue?
Thanks.
4 返答(返信)
2,265件の閲覧回数
danielmartynek
Hi @VanNgo285,
Which version of the S32DS IDE did you install?
SDK 3.0.0 is compatible with S32DS 2.2
If the SDK is not included by default, you will need to add it manually.
2,254件の閲覧回数
VanNgo285
Hi @Daniel,
I installed version S32DS 2.2.
Sorry, I am new in S32K. Can you show me the tutorial about how to add SDK to project ?
Thank you very much
2,234件の閲覧回数
danielmartynek
Hi @VanNgo285,
As far as I know, we can't add the drivers into an existing project.
The project should be created with the SDK.
BR, Daniel
2,226件の閲覧回数
VanNgo285
Thank you very much
