S32DS ARM
S32DS ARM
2,285 次查看
VanNgo285
I just installed S32DS ARM. I open my project but project's SDKs seem like wrong.
How to fix this issue?
Thanks.
4 回复数
2,254 次查看
danielmartynek
Hi @VanNgo285,
Which version of the S32DS IDE did you install?
SDK 3.0.0 is compatible with S32DS 2.2
If the SDK is not included by default, you will need to add it manually.
2,243 次查看
VanNgo285
Hi @Daniel,
I installed version S32DS 2.2.
Sorry, I am new in S32K. Can you show me the tutorial about how to add SDK to project ?
Thank you very much
2,223 次查看
danielmartynek
Hi @VanNgo285,
As far as I know, we can't add the drivers into an existing project.
The project should be created with the SDK.
BR, Daniel
2,215 次查看
VanNgo285
Thank you very much
