S32DS ARM activation failed
29,664件の閲覧回数
lps629
Hi, Support Team
i download S32DS ARM 1.3/2.0 and try to activate it, but it failed online and offline mode, i tried many times, but it still not work, below is the log file, could you help me solve this problem, thanks!
__________________________________________________________________________
Tue Nov 12 11:28:00 CST 2019
Free Memory: 18652 kB
Total Memory: 33656 kB
java.class.path:
C:\Users\XH\AppData\Local\Temp\I1573480043\InstallerData\IAClasses.zip
C:\Users\XH\AppData\Local\Temp\I1573480043\InstallerData\Execute.zip
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\InstallerData\Execute.zip
C:\Users\XH\AppData\Local\Temp\I1573480043\InstallerData\Resource1.zip
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\InstallerData\Resource1.zip
ZGUtil.CLASS_PATH:
sun.boot.class.path:
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\lib\resources.jar
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\lib\rt.jar
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\lib\sunrsasign.jar
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\lib\jsse.jar
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\lib\jce.jar
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\lib\charsets.jar
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\lib\jfr.jar
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\classes
java.ext.dirs:
C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\lib\ext
C:\Windows\Sun\Java\lib\ext
java.version == 1.8.0_51 (Java 1)
java.vm.name == Java HotSpot(TM) Client VM
java.vm.vendor == Oracle Corporation
java.vm.version == 25.51-b03
java.vm.specification.name == Java Virtual Machine Specification
java.vm.specification.vendor == Oracle Corporation
java.vm.specification.version == 1.8
java.specification.name == Java Platform API Specification
java.specification.vendor == Oracle Corporation
java.specification.version == 1.8
java.vendor == Oracle Corporation
java.vendor.url == http://java.oracle.com/
java.class.version == 52.0
java.library.path == C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files (x86)\Lenovo\Access Connections\;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x86;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x64;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x86;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x64;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\ThinkPad\Bluetooth Software\;C:\Program Files\ThinkPad\Bluetooth Software\syswow64;C:\Program Files\MATLAB\R2019b\runtime\win64;C:\Program Files\MATLAB\R2019b\bin;C:\Program Files\MATLAB\R2017a\runtime\win64;C:\Program Files\MATLAB\R2017a\bin;C:\Program Files\MATLAB\R2019b\polyspace\bin;C:\Program Files\TortoiseSVN\bin;C:\Users\XH\AppData\Local\Programs\Python\Python36\Scripts\;C:\Users\XH\AppData\Local\Programs\Python\Python36\;.
java.compiler == null
java.home == C:\Users\XH\AppData\Local\Temp\I1573480043\Windows\resource\jre
java.io.tmpdir == C:\Users\XH\AppData\Local\Temp\
os.name == Windows 7
os.arch == x86
os.version == 6.1
path.separator == ;
file.separator == \
file.encoding == GBK
user.name == XH
user.home == C:\Users\XH
user.dir == C:\Users\XH\AppData\Local\Temp\I1573480043\Windows
user.language == en
user.region == null
Installed Feature(s) S32DSF of S32 Design Studio for ARM v2.0
Install Begin: NOVEMBER 11, 2019 9:48:33 PM CST
Install End: NOVEMBER 12, 2019 11:27:57 AM CST
Installed by InstallAnywhere 16.5 Professional Build 4860
User Interactions
#Choose additional feature(s)
CHOSEN_FEATURE_LIST=S32DSF
CHOSEN_INSTALL_FEATURE_LIST=S32DSF
CHOSEN_INSTALL_SET=S32 Des
#Choose Install Location
USER_INSTALL_DIR=C:\\NXP\\S32DS_ARM_v2.0
#Choose Shortcut Folder
USER_SHORTCUTS=C:\\Users\\XH\\AppData\\Roaming\\Microsoft\\Windows\\Start Menu\\Programs\\NXP S32 Design Studio\\S32 Design Studio for ARM v2.0
#Install
-fileOverwrite_C\:\\NXP\\S32DS_ARM_v2.0\\_S32\ Design\ Studio\ for\ ARM\ v2.0_installation\\resource\\iawin32.dll=Yes
-fileOverwrite_C\:\\NXP\\S32DS_ARM_v2.0\\_S32\ Design\ Studio\ for\ ARM\ v2.0_installation\\resource\\win64_32_x64.exe=Yes
-fileOverwrite_C\:\\NXP\\S32DS_ARM_v2.0\\_S32\ Design\ Studio\ for\ ARM\ v2.0_installation\\resource\\remove.exe=Yes
-fileOverwrite_C\:\\NXP\\S32DS_ARM_v2.0\\_S32\ Design\ Studio\ for\ ARM\ v2.0_installation\\resource\\invoker.exe=Yes
Summary
Installation: Unsuccessful.
34 Successes
6 Warnings
1 NonFatalErrors
1 FatalErrors
Action Notes:
None
Install Log Detail:
Check Disk Space: C:\NXP\S32DS__v2.0
Status: SUCCESSFUL
Additional Notes: NOTE - Required Disk Space: 2,445,121,672; Free Disk Space: 44,791,119,872
Check Disk Space: C:\NXP\S32DS_ARM_v2.0
Status: SUCCESSFUL
Install Directory: C:\NXP\S32DS_ARM_v2.0\jre
Status: SUCCESSFUL
Install JRE: C:\NXP\S32DS_ARM_v2.0\jre
Status: SUCCESSFUL
Install Directory: C:\Users\XH\AppData\Local\Temp\021245.tmp\
Status: SUCCESSFUL
Additional Notes: NOTE - Directory already existed
Execute Command: NET SESSION
Status: SUCCESSFUL
Install File: C:\Users\XH\AppData\Local\Temp\021245.tmp\vcredist_2013_x86.exe
Status: SUCCESSFUL
Expand Archive: C:\Users\XH\AppData\Local\Temp\021245.tmp\vcredist.zip
Status: SUCCESSFUL
Install File: C:\Users\XH\AppData\Local\Temp\021245.tmp\vcredist_2010SP1_x86.exe
Status: SUCCESSFUL
Expand Archive: C:\Users\XH\AppData\Local\Temp\021245.tmp\vcredist2010.zip
Status: SUCCESSFUL
Execute Command: C:\Users\XH\AppData\Local\Temp\021245.tmp\vcredist_2013_x86.exe /quiet
Status: SUCCESSFUL
Execute Command: C:\Users\XH\AppData\Local\Temp\021245.tmp\vcredist_2010SP1_x86.exe /quiet
Status: SUCCESSFUL
Install File: C:\Users\XH\AppData\Local\Temp\021245.tmp\FNPLicensingService\FNPLicensingService
Status: SUCCESSFUL
Install File: C:\Users\XH\AppData\Local\Temp\021245.tmp\install_fnp.sh
Status: SUCCESSFUL
Install File: C:\Users\XH\AppData\Local\Temp\021245.tmp\license.jar
Status: SUCCESSFUL
Expand Archive: C:\Users\XH\AppData\Local\Temp\021245.tmp\Activation.zip
Status: SUCCESSFUL
Execute Command: java -Djava.library.path=. -jar "C:\Users\XH\AppData\Local\Temp\021245.tmp\license.jar" install -prod S32-DS-ARM_v2.0
Status: SUCCESSFUL
Execute Command: java -Djava.library.path=. -jar "C:\Users\XH\AppData\Local\Temp\021245.tmp\license.jar" verify -feature Activated -version 2.0 -prod S32-DS-ARM_v2.0
Status: SUCCESSFUL
Execute Command: java -Djava.library.path=. -jar "C:\Users\XH\AppData\Local\Temp\021245.tmp\license.jar" run -feature Activated -version 2.0 -prod S32-DS-ARM_v2.0
Status: SUCCESSFUL
Execute Command: java -Djava.library.path=. -jar "C:\Users\XH\AppData\Local\Temp\021245.tmp\license.jar" list
Status: SUCCESSFUL
Install Uninstaller: S32 Design Studio for ARM v2.0(Install All Uninstaller Components)
Status: SUCCESSFUL
Install Directory: C:\NXP\S32DS_ARM_v2.0\_S32 Design Studio for ARM v2.0_installation\resource\
Status: SUCCESSFUL
Install File: C:\NXP\S32DS_ARM_v2.0\_S32 Design Studio for ARM v2.0_installation\resource\iawin32.dll
Status: SUCCESSFUL
Install File: C:\NXP\S32DS_ARM_v2.0\_S32 Design Studio for ARM v2.0_installation\resource\win64_32_x64.exe
Status: SUCCESSFUL
Install File: C:\NXP\S32DS_ARM_v2.0\_S32 Design Studio for ARM v2.0_installation\resource\remove.exe
Status: SUCCESSFUL
Install File: C:\NXP\S32DS_ARM_v2.0\_S32 Design Studio for ARM v2.0_installation\resource\invoker.exe
Status: SUCCESSFUL
Status: ERROR
Additional Notes: ERROR - Error writing LaunchAnywhere components (Access Denied)
Uninstall File: C:\Users\XH\AppData\Local\Temp\021245.tmp\vcredist_2013_x86.exe
Status: WARNING
Additional Notes: WARNING - The file does not exist
Uninstall File: C:\Users\XH\AppData\Local\Temp\021245.tmp\vcredist_2010SP1_x86.exe
Status: WARNING
Uninstall File: C:\Users\XH\AppData\Local\Temp\021245.tmp\FNPLicensingService\FNPLicensingService
Status: WARNING
Uninstall File: C:\Users\XH\AppData\Local\Temp\021245.tmp\install_fnp.sh
Status: WARNING
Uninstall File: C:\Users\XH\AppData\Local\Temp\021245.tmp\license.jar
Status: WARNING
Uninstall Folder: C:\Users\XH\AppData\Local\Temp\021245.tmp\FNPLicensingService
Status: WARNING
Additional Notes: WARNING - The path does not exist
Uninstall Folder: C:\NXP\S32DS_ARM_v2.0\jre
Status: SUCCESSFUL
Status: SUCCESSFUL
Remove Registry Entry: 5 HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\null
Status: SUCCESSFUL
Error occurred while installing the following Action, hence rolling back the installation....!
Action Name: Trigger Rollback Action
Action Description: Trigger Rollback Action
Error Details as below:
This action rolls back the Installation.
====================STDERR ENTRIES==================
InstallAnywhere 2014 SP1
Version: 16.5
Mon Nov 11 21:48:28 CST 2019
Free Memory: 10576 kB
Total Memory: 15872 kB
No Arguments
java.class.path:
ZGUtil.CLASS_PATH:
java.ext.dirs:
os.arch == x86
os.version == 6.1
path.separator == ;
file.separator == \
user.name == XH
user.language == zh
user.region == null
Loading externalized properties
RepositoryManager: Trying fallback repository location...
# INSTALLING VM: C:\NXP\S32DS_ARM_v2.0\jre
System's temporary directory = C:\Users\XH\AppData\Local\Temp
==== License service installation log start: ====
==== License service installation log end. ====
==== License activation log start: ====
CLLReason [errorNo=40, errorString=Error sending an activation request to a remote activation server and processing the resulting response. Failed to connect to the license server or Operations server. (FNP error 50041,41143,34), flxActMajorErrorNo=50041, flxActMinorErrorNo=41143, flxActSysErrorNo=34, flxCommErrorNo=0]
CLLReason [errorNo=34, errorString=Invalid offline response, ResponseType, flxActMajorErrorNo=0, flxActMinorErrorNo=0, flxActSysErrorNo=0, flxCommErrorNo=0]
No activation Id was entered
==== License activation log end. ====
==== License list start: ====
==== License list end. ====
XMLScriptWriter: No Installation Objects were skipped
8. final log file name=C:\NXP\S32DS_ARM_v2.0\_S32 Design Studio for ARM v2.0_installation\Logs\S32_Design_Studio_for_ARM_v2.0_Install_11_12_2019_11_28_00.log
====================STDOUT ENTRIES==================
C:\NXP\S32DS_ARM_v2.0\jre\bin
C:\NXP\S32DS_ARM_v2.0\jre\bin\awt.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\bci.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\client
C:\NXP\S32DS_ARM_v2.0\jre\bin\client\classes.jsa
C:\NXP\S32DS_ARM_v2.0\jre\bin\client\jvm.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\client\Xusage.txt
C:\NXP\S32DS_ARM_v2.0\jre\bin\dcpr.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\decora_sse.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\deploy.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\dtplugin
C:\NXP\S32DS_ARM_v2.0\jre\bin\dtplugin\deployJava1.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\dtplugin\npdeployJava1.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\dt_shmem.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\dt_socket.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\eula.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\fontmanager.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\fxplugins.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\glass.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\glib-lite.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\gstreamer-lite.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\hprof.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\instrument.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\j2pcsc.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\j2pkcs11.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jaas_nt.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jabswitch.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\java-rmi.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\java.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\java.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\JavaAccessBridge.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\javacpl.cpl
C:\NXP\S32DS_ARM_v2.0\jre\bin\javacpl.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\javafx_font.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\javafx_font_t2k.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\javafx_iio.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\javaw.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\javaws.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\java_crw_demo.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jawt.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\JAWTAccessBridge.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jdwp.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jfr.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jfxmedia.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jfxwebkit.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jjs.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\jli.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jp2iexp.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jp2launcher.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\jp2native.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jp2ssv.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jpeg.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jsdt.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jsound.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\jsoundds.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\kcms.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\keytool.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\kinit.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\klist.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\ktab.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\lcms.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\management.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\mlib_image.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\msvcr100.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\net.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\nio.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\npt.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\orbd.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\pack200.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\plugin2
C:\NXP\S32DS_ARM_v2.0\jre\bin\plugin2\msvcr100.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\plugin2\npjp2.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\policytool.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\prism_common.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\prism_d3d.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\prism_es2.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\prism_sw.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\resource.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\rmid.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\rmiregistry.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\servertool.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\splashscreen.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\ssv.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\ssvagent.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\sunec.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\sunmscapi.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\t2k.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\tnameserv.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\unpack.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\unpack200.exe
C:\NXP\S32DS_ARM_v2.0\jre\bin\verify.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\w2k_lsa_auth.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\WindowsAccessBridge.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\wsdetect.dll
C:\NXP\S32DS_ARM_v2.0\jre\bin\zip.dll
C:\NXP\S32DS_ARM_v2.0\jre\COPYRIGHT
C:\NXP\S32DS_ARM_v2.0\jre\lib
C:\NXP\S32DS_ARM_v2.0\jre\lib\accessibility.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\calendars.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\charsets.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\classlist
C:\NXP\S32DS_ARM_v2.0\jre\lib\cmm
C:\NXP\S32DS_ARM_v2.0\jre\lib\cmm\CIEXYZ.pf
C:\NXP\S32DS_ARM_v2.0\jre\lib\cmm\GRAY.pf
C:\NXP\S32DS_ARM_v2.0\jre\lib\cmm\LINEAR_RGB.pf
C:\NXP\S32DS_ARM_v2.0\jre\lib\cmm\PYCC.pf
C:\NXP\S32DS_ARM_v2.0\jre\lib\cmm\sRGB.pf
C:\NXP\S32DS_ARM_v2.0\jre\lib\content-types.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\currency.data
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\ffjcext.zip
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_de.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_es.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_fr.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_it.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_ja.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_ko.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_pt_BR.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_sv.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_zh_CN.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_zh_HK.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\messages_zh_TW.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy\[email protected]
C:\NXP\S32DS_ARM_v2.0\jre\lib\deploy.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\access-bridge.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\cldrdata.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\dnsns.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\jaccess.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\jfxrt.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\localedata.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\meta-index
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\nashorn.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\sunec.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\sunjce_provider.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\sunmscapi.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\sunpkcs11.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\ext\zipfs.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\flavormap.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\fontconfig.bfc
C:\NXP\S32DS_ARM_v2.0\jre\lib\fontconfig.properties.src
C:\NXP\S32DS_ARM_v2.0\jre\lib\fonts
C:\NXP\S32DS_ARM_v2.0\jre\lib\fonts\LucidaBrightDemiBold.ttf
C:\NXP\S32DS_ARM_v2.0\jre\lib\fonts\LucidaBrightDemiItalic.ttf
C:\NXP\S32DS_ARM_v2.0\jre\lib\fonts\LucidaBrightItalic.ttf
C:\NXP\S32DS_ARM_v2.0\jre\lib\fonts\LucidaBrightRegular.ttf
C:\NXP\S32DS_ARM_v2.0\jre\lib\fonts\LucidaSansDemiBold.ttf
C:\NXP\S32DS_ARM_v2.0\jre\lib\fonts\LucidaSansRegular.ttf
C:\NXP\S32DS_ARM_v2.0\jre\lib\fonts\LucidaTypewriterBold.ttf
C:\NXP\S32DS_ARM_v2.0\jre\lib\fonts\LucidaTypewriterRegular.ttf
C:\NXP\S32DS_ARM_v2.0\jre\lib\hijrah-config-umalqura.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\i386
C:\NXP\S32DS_ARM_v2.0\jre\lib\i386\jvm.cfg
C:\NXP\S32DS_ARM_v2.0\jre\lib\images
C:\NXP\S32DS_ARM_v2.0\jre\lib\images\cursors
C:\NXP\S32DS_ARM_v2.0\jre\lib\images\cursors\cursors.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\javafx.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\javaws.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\jce.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\jfr
C:\NXP\S32DS_ARM_v2.0\jre\lib\jfr\default.jfc
C:\NXP\S32DS_ARM_v2.0\jre\lib\jfr\profile.jfc
C:\NXP\S32DS_ARM_v2.0\jre\lib\jfr.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\jfxswt.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\jsse.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\jvm.hprof.txt
C:\NXP\S32DS_ARM_v2.0\jre\lib\logging.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\management
C:\NXP\S32DS_ARM_v2.0\jre\lib\management\jmxremote.access
C:\NXP\S32DS_ARM_v2.0\jre\lib\management\jmxremote.password.template
C:\NXP\S32DS_ARM_v2.0\jre\lib\management\management.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\management\snmp.acl.template
C:\NXP\S32DS_ARM_v2.0\jre\lib\management-agent.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\meta-index
C:\NXP\S32DS_ARM_v2.0\jre\lib\net.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\plugin.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\psfont.properties.ja
C:\NXP\S32DS_ARM_v2.0\jre\lib\psfontj2d.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\resources.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\rt.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\security
C:\NXP\S32DS_ARM_v2.0\jre\lib\security\blacklist
C:\NXP\S32DS_ARM_v2.0\jre\lib\security\blacklisted.certs
C:\NXP\S32DS_ARM_v2.0\jre\lib\security\cacerts
C:\NXP\S32DS_ARM_v2.0\jre\lib\security\java.policy
C:\NXP\S32DS_ARM_v2.0\jre\lib\security\java.security
C:\NXP\S32DS_ARM_v2.0\jre\lib\security\javaws.policy
C:\NXP\S32DS_ARM_v2.0\jre\lib\security\local_policy.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\security\trusted.libraries
C:\NXP\S32DS_ARM_v2.0\jre\lib\security\US_export_policy.jar
C:\NXP\S32DS_ARM_v2.0\jre\lib\sound.properties
C:\NXP\S32DS_ARM_v2.0\jre\lib\tzdb.dat
C:\NXP\S32DS_ARM_v2.0\jre\lib\tzmappings
C:\NXP\S32DS_ARM_v2.0\jre\LICENSE
C:\NXP\S32DS_ARM_v2.0\jre\README.txt
C:\NXP\S32DS_ARM_v2.0\jre\release
C:\NXP\S32DS_ARM_v2.0\jre\THIRDPARTYLICENSEREADME-JAVAFX.txt
C:\NXP\S32DS_ARM_v2.0\jre\THIRDPARTYLICENSEREADME.txt
C:\NXP\S32DS_ARM_v2.0\jre\Welcome.html
C:\NXP\S32DS_ARM_v2.0\_S32 Design Studio for ARM v2.0_installation\.com.zerog.registry.xml
C:\NXP\S32DS_ARM_v2.0\_S32 Design Studio for ARM v2.0_installation\InstallScript.iap_xml
C:\NXP\S32DS_ARM_v2.0\_S32 Design Studio for ARM v2.0_installation\uninstaller.jar
3 返答(返信)
29,395件の閲覧回数
dianabatrlova
Hi Peisong,
I recommend you to install the newest version S32 Design Studio for ARM 2018.R1 available on this link:
https://www.nxp.com/design/software/development-software/s32-design-studio-ide/s32-design-studio-for...
Note: Please, use the activation key from the web portal.
I hope it helps.
Diana
29,395件の閲覧回数
xuzhao
Hi Diana
I have the same issue. I am sure i installed the latest version S32 Design Studio for ARM 2018.R1. I have used it for about 1 year, but today it does not work with warning popout 'invalid  license'. so i have to re-install it, but now i can not activate it.
Please help me out. Thank you very much.
29,395件の閲覧回数
dianabatrlova
You can try offline activation. This document was created for the older S32DS with an offline activation issue.
So, you can skip downloading licfix.zip and running clean.bat. and directly choose offline activation during installation and create an activation request.
https://community.nxp.com/docs/DOC-334344
I hope it helps.
Diana
