S32 for ARM Processor Expert Configuration
已解决
跳至解决方案
1,740 次查看
engineer_attila
Hi folks,
My IDE version is ARMv2.2, SDK: RTM3.0.0.
I want to use SPI program for my 48-LQFP S32K144 board.When i select example project or create a new project, ı couldn't change the S32k144 for 48 pin. .The default config for S32 CPU S32K144_100.
How can i select proper configuration
Best regards.
1 解答
1,725 次查看
VaneB
Hi @engineer_attila
Take a look at below community post:
B.R
VaneB
在原帖中查看解决方案
1 回复
1,726 次查看
VaneB
Hi @engineer_attila
B.R
VaneB
