S32 design studio
3,733件の閲覧回数
Binge
Is there any way to check the core clocks(running time) of a function in S32DS?
Binge.
3,647件の閲覧回数
Daniel-Aguirre
There is a thread that talks about a different platform but provides some ideas of the execution time:
Solved: How can I measure the execution time of a function... - NXP Community
Another idea is what it was already provided, which is using a timer to measure the entry and exit of the function, it just needs to be set so that it stops when the debugging session is halted by a breakpoint.
Another possibility is provided under the thread, which is measuring by executed instructions under the function.
There is also an explanation provided under the following AN:
Measuring Interrupt Latency (nxp.com)
Which could be of use.
Please, let us know.
4 返答(返信)
3,667件の閲覧回数
YanyiQiu
Please refer to
1. use gpio (set high before code execution , set low after code execution) and hard oscilloscope
2. timer tick count (system time tick or other)
please consider the impact of an interruption
3,714件の閲覧回数
Daniel-Aguirre
Can you help us elaborate more on your request? We understand that are trying to measure the execution time of a function, but we are not completely sure about it.
3,691件の閲覧回数
Binge
Yes,I am  trying to measure the execution time of a function or a code segment.Please tell me how to do that?
Binge.
3,648件の閲覧回数
Daniel-Aguirre
