S32 autosar
S32 autosar
dream_lostcity
Is it possible to generate AUTOSAR-compliant code only by using S32DS with the RTD package and without EB Tresos? If yes, what is the specific implementation method?
petervlna
Can S32DS + RTD alone generate AUTOSAR-compliant code?
No.
To be AUTOSAR-compliant, you must have:
MCAL (drivers) → RTD can play this role
BSW stack (Com, DCM, NvM, etc.)
RTE (Runtime Environment)
ARXML-based configuration
System configuration tool (like tresos/DaVinci)
These elements are mandatory in AUTOSAR architecture.
Peter
%3CLINGO-SUB%20id%3D%22lingo-sub-2364441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32%20autosar%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2364441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIs%20it%20possible%20to%20generate%20AUTOSAR-compliant%20code%20only%20by%20using%20S32DS%20with%20the%20RTD%20package%20and%20without%20EB%20Tresos%3F%20If%20yes%2C%20what%20is%20the%20specific%20implementation%20method%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2364580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20autosar%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2364580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3ECan%20S32DS%20%2B%20RTD%20alone%20generate%20AUTOSAR-compliant%20code%3F%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3ENo.%3C%2FP%3E%0A%3CP%3ETo%20be%20AUTOSAR-compliant%2C%20you%20must%20have%3A%3C%2FP%3E%0A%3CP%3E%3CLI-EMOJI%20id%3D%22lia_white-heavy-check-mark%22%20title%3D%22%3Awhite_heavy_check_mark%3A%22%3E%3C%2FLI-EMOJI%3E%20MCAL%20(drivers)%20%E2%86%92%20RTD%20can%20play%20this%20role%3CBR%20%2F%3E%3CLI-EMOJI%20id%3D%22lia_cross-mark%22%20title%3D%22%3Across_mark%3A%22%3E%3C%2FLI-EMOJI%3E%20BSW%20stack%20(Com%2C%20DCM%2C%20NvM%2C%20etc.)%3CBR%20%2F%3E%3CLI-EMOJI%20id%3D%22lia_cross-mark%22%20title%3D%22%3Across_mark%3A%22%3E%3C%2FLI-EMOJI%3E%20RTE%20(Runtime%20Environment)%3CBR%20%2F%3E%3CLI-EMOJI%20id%3D%22lia_cross-mark%22%20title%3D%22%3Across_mark%3A%22%3E%3C%2FLI-EMOJI%3E%20ARXML-based%20configuration%3CBR%20%2F%3E%3CLI-EMOJI%20id%3D%22lia_cross-mark%22%20title%3D%22%3Across_mark%3A%22%3E%3C%2FLI-EMOJI%3E%20System%20configuration%20tool%20(like%20tresos%2FDaVinci)%3C%2FP%3E%0A%3CP%3EThese%20elements%20are%20mandatory%20in%20AUTOSAR%20architecture.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%3C%2FLINGO-BODY%3E
