S32 Design Studio have some codes files of example, but it do not exist in the computer local.
327件の閲覧回数
lyz
S32 Design Studio  IDE have codes files from example, but it do not exist in the computer local. as follow:
3 返答(返信)
174件の閲覧回数
lyz
创建的例程SDK代码不会保存在本地,可以自己新建一个APP工程,根据该例程适配各个模块,在generate后,本地就有SDK文件
166件の閲覧回数
Julián_AragónM
Hi @lyz,
Yes. When importing an example, SDK files are generated as a link, but when you create an application from scratch, you can see the files locally:
Julián
307件の閲覧回数
Julián_AragónM
Hi @lyz,
The files under SDK folder are not copied into the workspace directory, rather they are linked to the SDK installation:
I guess this is done to reduce space occupied by driver files, so they are not copied for every project every time.
Julián
