S32 Design Studio for S32 Platform have error message
2,190 次查看
Lita
When I open a routine (Adc_Example_s32k344) and select configuration, I get an error box like the one shown in the figure(The current tool version does not support processor S32K344 (release_id) version). How can I solve this problem?
破坏者
4 回复数
2,103 次查看
Senlent
Hi@Lita
I didn't receive any file from your side,but I see you said the wrong note is :Processor S32K344, PlatformSDK_S32k_2022_07 version is not supported by the current version of the tool.
that is because you may not installed S32K3 RTD 2.0.1
2,073 次查看
Lita
ths so much
2,065 次查看
Senlent
Hi@Lita
I told you before, did you try to install RTD 2.0.1 to solve the problem? I think the root cause is that you don't have RTD 2.0.1 installed.
2,168 次查看
Senlent
Hi@Lita
I don't see any picture on your description,can you confirm that?.
