S32 Design Studio for ARM 2018.R1 Install new software connection not working
Alex999
I was used to installing the packages I needed via the "Install new software" pane. I use NXP occasionally. Now I'm not able to connect to the software site. Can you help me?
Attached, you can find a screenshot.
VaneB
Hi @Alex999
This error is typically caused by network or firewall restrictions that block secure HTTPS connections or interfere with SSL certificate validation.
Please check with your IT department to ensure that there are no blocks or proxy configurations preventing access to the update site.
BR, VaneB
%3CLINGO-SUB%20id%3D%22lingo-sub-2258293%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32%20Design%20Studio%20for%20ARM%202018.R1%20Install%20new%20software%20connection%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2258293%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI%20was%20used%20to%20installing%20the%20packages%20I%20needed%20via%20the%20%22Install%20new%20software%22%20pane.%20I%20use%20NXP%20occasionally.%20Now%20I'm%20not%20able%20to%20connect%20to%20the%20software%20site.%20Can%20you%20help%20me%3F%3C%2FP%3E%3CP%3EAttached%2C%20you%20can%20find%20a%20screenshot.%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2259401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20Design%20Studio%20for%20ARM%202018.R1%20Install%20new%20software%20connection%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2259401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F257823%22%20target%3D%22_blank%22%3E%40Alex999%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThis%20error%20is%20typically%20caused%20by%20network%20or%20firewall%20restrictions%20that%20block%20secure%20HTTPS%20connections%20or%20interfere%20with%20SSL%20certificate%20validation.%3C%2FP%3E%0A%3CP%3EPlease%20check%20with%20your%20IT%20department%20to%20ensure%20that%20there%20are%20no%20blocks%20or%20proxy%20configurations%20preventing%20access%20to%20the%20update%20site.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%2C%20VaneB%3C%2FP%3E%3C%2FLINGO-BODY%3E
