S32 Design Studio 3.5 +Flashing issue when try to program through OPEN SDA
15,331 次查看
nkarthik
I am  facing flashin issue when try to  program through OPEN SDA
14,708 次查看
nkarthik
Hi Senlent,
 Thank you for the extended support. I am able to flash now.
Root cause : Antivirus block the NXP-S32Ds SW .dll.
14 回复数
14,706 次查看
nkarthik
Hi Nxp team,
Can you please add Guideline doc's or checklist in the SW installation about the list of .dll needs to be whitelisted in the Antivirus.
Thanks Regards
Karthik.N
14,999 次查看
Senlent
Hi@nkarthik
I sent you a document via private message.
This document records the complete process of installing the development environment.
If this document still cannot solve your problem, then I don’t know how to solve your problem.
15,008 次查看
nkarthik
Target selected and Port is not detected
15,310 次查看
nkarthik
Hi Senlent,
 Please find attached document related to steps.
15,295 次查看
Senlent
Hi@nkarthik
please select a right target device in the highlight button and then try again.
14,709 次查看
nkarthik
Hi Senlent,
15,281 次查看
nkarthik
I am not able to select device and port
15,258 次查看
Senlent
Hi@nkarthik
please check whether the plug-in has been installed correctly.
15,172 次查看
nkarthik
Already installed PE-micro-Debug and working.
15,171 次查看
nkarthik
PE-Debug is installed and still the issue is not resolved
15,166 次查看
Senlent
Hi@nkarthik
If your problem is not solved, please still record the steps you took, otherwise I will not be able to help you analyze and solve it.
15,314 次查看
Senlent
Hi@nkarthik
could you please record the steps when you programming, so that i could help you troubleshooting the possible causes.
take a look at this post which may useful to you.
https://community.nxp.com/t5/S32-Design-Studio/Cannot-run-program-quot-gdb-quot-Launching-failed/m-p...
15,102 次查看
nkarthik
hi Nxp Team,
 Here is the flashing issue  snapshot and EVL Board (Power connected).please help to resolve this issue
15,095 次查看
Senlent
Hi@nkarthik
Let me double check it with you that you already can select target device?
