S32 Design Studio 3.5 +Flashing issue when try to program through OPEN SDA
15,129件の閲覧回数
nkarthik
I am  facing flashin issue when try to  program through OPEN SDA
14,506件の閲覧回数
nkarthik
Hi Senlent,
 Thank you for the extended support. I am able to flash now.
Root cause : Antivirus block the NXP-S32Ds SW .dll.
14 返答(返信)
14,504件の閲覧回数
nkarthik
Hi Nxp team,
Can you please add Guideline doc's or checklist in the SW installation about the list of .dll needs to be whitelisted in the Antivirus.
Thanks Regards
Karthik.N
14,797件の閲覧回数
Senlent
Hi@nkarthik
I sent you a document via private message.
This document records the complete process of installing the development environment.
If this document still cannot solve your problem, then I don’t know how to solve your problem.
14,806件の閲覧回数
nkarthik
Target selected and Port is not detected
15,108件の閲覧回数
nkarthik
Hi Senlent,
 Please find attached document related to steps.
15,093件の閲覧回数
Senlent
Hi@nkarthik
please select a right target device in the highlight button and then try again.
14,507件の閲覧回数
nkarthik
Hi Senlent,
15,079件の閲覧回数
nkarthik
I am not able to select device and port
15,056件の閲覧回数
Senlent
Hi@nkarthik
please check whether the plug-in has been installed correctly.
14,970件の閲覧回数
nkarthik
Already installed PE-micro-Debug and working.
14,969件の閲覧回数
nkarthik
PE-Debug is installed and still the issue is not resolved
14,964件の閲覧回数
Senlent
Hi@nkarthik
If your problem is not solved, please still record the steps you took, otherwise I will not be able to help you analyze and solve it.
15,112件の閲覧回数
Senlent
Hi@nkarthik
could you please record the steps when you programming, so that i could help you troubleshooting the possible causes.
take a look at this post which may useful to you.
https://community.nxp.com/t5/S32-Design-Studio/Cannot-run-program-quot-gdb-quot-Launching-failed/m-p...
14,900件の閲覧回数
nkarthik
hi Nxp Team,
 Here is the flashing issue  snapshot and EVL Board (Power connected).please help to resolve this issue
14,893件の閲覧回数
Senlent
Hi@nkarthik
Let me double check it with you that you already can select target device?
