Remove write protection on S32K146
1,803 次查看
vladimir_novac
Good day,
We have a custom board with S32K146 MCU and we are using SEGGER J-Flash to flash it. But now we have problems with write protection.
First when we are trying to connect we are getting this message:
If answer YES, J-Flash is asking the same question encore 3 times, and after that the connection will not be established with the message
If answer NO, the connection establishes but if we will try to erase chip, we are getting error and then target disconnects
We will appreciate any help to unlock write protection.
Vladimir Novac
Embedded Software Developer at Irdeto
0 回复数
