Remove s32K146 variant handle from a module
shubham_prajapati
Currently I have 3 variants in project. For the MCU module.
Previously I was maintaining three configuration files (eg. MCU_Variant1_PBcfg, MCU_Variant2_PBcfg & MCU_Variant3_PBcfg). This was done by adding variant criterion option shown below:
Now I want to have just one configuration file (MCU_PBcfg) common for all the variants. To do this I have removed the variant option from the MCU module parameter as shown:
But I am getting the below errors. Can u please guide on this?
Shubham
namnguyenviet
Or you can try to disable the EcuCPostBuildVariant:
Nam
namnguyenviet
Hello @shubham_prajapati,
If you want to keep only one variant, then you can remove unused post-build variant ref:
However, my understanding is you want to remove the whole variant concept (as a result the configuration file name will not contain the variant name, e.g. Mcu_PBCfg.c instead of Mcu_PBCfg_VS_0.c). In that case, it would be more complicated, and as my experience, here are the steps I often do:
1. Export the configuration from the variant which I want to keep to .epc files
2. Emove all of the modules and the .xdm files
3. Re-add all of the modules
4. Import the .epc files from step 1.
Nam
