Regarding LIN protocol
1,046件の閲覧回数
adwaitparth
After flashing the example code of LIN for NXP on Trace 32, I am not able to receive the desired message on the Logic Analyzer.
1,023件の閲覧回数
Julián_AragónM
Hi @adwaitparth,
Could you share which device you are using? As well as which RTD (or SDK) package and its version. Also, is this an example from the drivers?
For S32K1, you can download the LIN stack package as mentioned in this post: Solved: Re: LIN Middleware stack missing - NXP Community
You can find examples for both S32K1 & S32K3 derivatives inside the Real-Time Drivers (RTD):
Julián
