Reg: S32K322 ABI + PWM encoder Sample software
Thiru2483
Hi Team,
We are currently working for the Position sensor for the ABI + PWM method.
Requesting to share the example software and document to capture and Process the inital angle using the PWM and runtime angle switching will be with ABI enocder method using the S32K322 microntroller
Tags (2)
PetrS
you can refer to below thread
https://community.nxp.com/t5/S32K-Knowledge-Base/S32K3-Motor-control-SW-examples/ta-p/1804577
it gives summary of S32K3 Motor control SW examples. The FOC examples themselves do not use the encoder (due to missing on HW kit), but the SW fully supports encoder-based FOC, and the SW App notes provides description how it can be enabled and integrated.
BR, Petr
