Reference code to handle ECC errors in S32K144 Flash Memory (P-Flash, FlexNVM, FlexRAM)
366 次查看
NJ_NXP
Hello NXP Community,
I am implementing safety mechanisms on the S32K144 and need reference code for non-correctable (double-bit) ECC errors, alongside a method to inject them for testing.
1. Double-Bit Handling
I need code examples to catch double-bit faults across:
  • P-Flash & FlexNVM:
  • FlexRAM (EEE): Detecting faults during background copies.
  • Exception Handlers: A BusFault or HardFault ISR routine to isolate the failing memory address.
2. Error Injection
What is the recommended way to simulate a double-bit fault in the Flash memory arrays
Any code snippets would be highly appreciated.
1 回复
337 次查看
danielmartynek
Hi @NJ_NXP,
1.
If you are using RTD drivers, refer to the Integration Manual for the S32K1/S32M24x FLS Driver (RTD_FLS_IM.pdf), specifically Section 10.4.1 – ECC Management on Internal Flash.
The document can be found in the RTD installation directory, for example for RTD 3.0.0_QLP02:
SW32K1_S32M24x_RTD_4.4_3.0.0_QLP02\eclipse\plugins\Fls_TS_T40D2M30I0R0\doc\
Regarding FlexRAM, it does not implement ECC. However, if a double-bit error is detected during a copy-down operation, the EEPROM record is read as all 1s.
For more details, see application note AN11983 – Using the S32K1xx EEPROM Functionality:
https://www.nxp.com/docs/en/application-note/AN11983.pdf
2.
The fault can be emulated in the flash controller by setting the FERCNFG[FDFD] bit and then performing a flash read.
Alternatively, the fault can be generated by reprogramming an already programmed flash phrase and subsequently reading it.
%3CLINGO-SUB%20id%3D%22lingo-sub-2383378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%94%A8%E4%BA%8E%E5%A4%84%E7%90%86%20S32K144%20%E9%97%AA%E5%AD%98%EF%BC%88P-Flash%E3%80%81FlexNVM%E3%80%81FlexRAM%EF%BC%89%E4%B8%AD%20ECC%20%E9%94%99%E8%AF%AF%E7%9A%84%E5%8F%82%E8%80%83%E4%BB%A3%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3ENXP%E7%A4%BE%E5%8C%BA%E7%9A%84%E5%90%84%E4%BD%8D%E6%9C%8B%E5%8F%8B%EF%BC%8C%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%81%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E6%88%91%E6%AD%A3%E5%9C%A8%3CSTRONG%3ES32K144%3C%2FSTRONG%3E%E4%B8%8A%E5%AE%9E%E7%8E%B0%3CSTRONG%3E%E5%8A%9F%E8%83%BD%E5%AE%89%E5%85%A8%E6%9C%BA%E5%88%B6%3C%2FSTRONG%3E%EF%BC%8C%E9%9C%80%E8%A6%81%E4%B8%8D%E5%8F%AF%E7%BA%A0%E6%AD%A3%EF%BC%88%E5%8F%8C%E4%BD%8D%EF%BC%89ECC%20%E9%94%99%E8%AF%AF%E7%9A%84%E5%8F%82%E8%80%83%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BB%A5%E5%8F%8A%E6%B3%A8%E5%85%A5%E8%BF%99%E4%BA%9B%E9%94%99%E8%AF%AF%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E7%9A%84%E6%96%B9%E6%B3%95%E3%80%82%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E1.%20%E5%8F%8C%E4%BD%8D%E5%A4%84%E7%90%86%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E6%88%91%E9%9C%80%E8%A6%81%E4%B8%80%E4%BA%9B%E4%BB%A3%E7%A0%81%E7%A4%BA%E4%BE%8B%E6%9D%A5%E6%8D%95%E8%8E%B7%E4%BB%A5%E4%B8%8B%E7%B1%BB%E5%9E%8B%E7%9A%84%E5%8F%8C%E6%AF%94%E7%89%B9%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FDIV%3E%3CUL%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3EP-Flash%20%E5%92%8C%20FlexNVM%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3EFlexRAM%EF%BC%88EEE%EF%BC%89%EF%BC%9A%3C%2FSTRONG%3E%E6%A3%80%E6%B5%8B%E5%90%8E%E5%8F%B0%E5%A4%8D%E5%88%B6%E8%BF%87%E7%A8%8B%E4%B8%AD%E7%9A%84%E6%95%85%E9%9A%9C%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3E%E5%BC%82%E5%B8%B8%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%EF%BC%9A%3C%2FSTRONG%3E%E4%B8%80%E4%B8%AA%20BusFault%20%E6%88%96%20HardFault%20ISR%20%E4%BE%8B%E7%A8%8B%EF%BC%8C%E7%94%A8%E4%BA%8E%E9%9A%94%E7%A6%BB%E6%95%85%E9%9A%9C%E5%86%85%E5%AD%98%E5%9C%B0%E5%9D%80%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E2.%20%E9%94%99%E8%AF%AF%E6%B3%A8%E5%85%A5%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E6%A8%A1%E6%8B%9F%3CSTRONG%3E%E9%97%AA%E5%AD%98%E9%98%B5%E5%88%97%3C%2FSTRONG%3E%E4%B8%AD%E7%9A%84%E5%8F%8C%E6%AF%94%E7%89%B9%E6%95%85%E9%9A%9C%E7%9A%84%E6%8E%A8%E8%8D%90%E6%96%B9%E6%B3%95%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E4%BB%BB%E4%BD%95%E4%BB%A3%E7%A0%81%E7%89%87%E6%AE%B5%E9%83%BD%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Reference%20code%20to%20handle%20ECC%20errors%20in%20S32K144%20Flash%20Memory%20(P-Flash%2C%20FlexNVM%2C%20FlexRAM)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F199505%22%20target%3D%22_blank%22%3E%40NJ_NXP%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%0A%3CP%3E1.%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AFRTD%E9%A9%B1%E5%8A%A8%E5%99%A8%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85S32K1%2FS32M24x%20FLS%E9%A9%B1%E5%8A%A8%E5%99%A8%E9%9B%86%E6%88%90%E6%89%8B%E5%86%8C%EF%BC%88RTD_FLS_IM.pdf%EF%BC%89%EF%BC%8C%E5%85%B7%E4%BD%93%E8%80%8C%E8%A8%80%EF%BC%8C%E6%98%AF%E7%AC%AC%2010.4.1%20%E8%8A%82%E2%80%94%E2%80%94%E5%86%85%E9%83%A8%E9%97%AA%E5%AD%98%E4%B8%8A%E7%9A%84%20ECC%20%E7%AE%A1%E7%90%86%E3%80%82%3CBR%20%2F%3E%E8%AF%A5%E6%96%87%E6%A1%A3%E4%BD%8D%E4%BA%8E%20RTD%20%E5%AE%89%E8%A3%85%E7%9B%AE%E5%BD%95%E4%B8%AD%EF%BC%8C%E4%BE%8B%E5%A6%82%20RTD%203.0.0_QLP02%20%E7%89%88%E6%9C%AC%EF%BC%9A%3CBR%20%2F%3ESW32K1_S32M24x_RTD_4.4_3.0.0_QLP02%5Ceclipse%5Cplugins%5CFls_TS_T40D2M30I0R0%5Cdoc%5C%3C%2FP%3E%0A%3CP%3E%E5%85%B3%E4%BA%8E%20FlexRAM%EF%BC%8C%E5%AE%83%E6%B2%A1%E6%9C%89%E5%AE%9E%E7%8E%B0%20ECC%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%9C%A8%E5%90%91%E4%B8%8B%E5%A4%8D%E5%88%B6%E6%93%8D%E4%BD%9C%E6%9C%9F%E9%97%B4%E6%A3%80%E6%B5%8B%E5%88%B0%E5%8F%8C%E4%BD%8D%E9%94%99%E8%AF%AF%EF%BC%8C%E5%88%99%20EEPROM%20%E8%AE%B0%E5%BD%95%E5%B0%86%E8%A2%AB%E8%AF%BB%E5%8F%96%E4%B8%BA%E5%85%A8%201%E3%80%82%3CBR%20%2F%3E%E6%9B%B4%E5%A4%9A%E8%AF%A6%E6%83%85%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%20AN11983%20%E2%80%93%20%E4%BD%BF%E7%94%A8%20S32K1xx%20EEPROM%20%E5%8A%9F%E8%83%BD%EF%BC%9A%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN11983.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN11983.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielmartynek_0-1781865940539.png%22%20style%3D%22width%3A%20752px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1781865940539.png%22%20style%3D%22width%3A%20752px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F389474iDA56119C2DE6AAF4%2Fimage-dimensions%2F752x173%3Fv%3Dv2%22%20width%3D%22752%22%20height%3D%22173%22%20role%3D%22button%22%20title%3D%22danielmartynek_0-1781865940539.png%22%20alt%3D%22danielmartynek_0-1781865940539.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E2.%3C%2FP%3E%0A%3CP%3E%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E8%AE%BE%E7%BD%AE%20FERCNFG%5BFDFD%5D%20%E4%BD%8D%E5%B9%B6%E6%89%A7%E8%A1%8C%E9%97%AA%E5%AD%98%E8%AF%BB%E5%8F%96%E6%9D%A5%E6%A8%A1%E6%8B%9F%E9%97%AA%E5%AD%98%E6%8E%A7%E5%88%B6%E5%99%A8%E4%B8%AD%E7%9A%84%E6%95%85%E9%9A%9C%E3%80%82%3CBR%20%2F%3E%E6%88%96%E8%80%85%EF%BC%8C%E4%B9%9F%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E9%87%8D%E6%96%B0%E7%BC%96%E7%A8%8B%E4%B8%80%E4%B8%AA%E5%B7%B2%E7%BC%96%E7%A8%8B%E7%9A%84%E9%97%AA%E5%AD%98%E7%9F%AD%E8%AF%AD%E5%B9%B6%E9%9A%8F%E5%90%8E%E8%AF%BB%E5%8F%96%E5%AE%83%E6%9D%A5%E4%BA%A7%E7%94%9F%E6%95%85%E9%9A%9C%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
