RappID Tool for S32K144
gopichakrala
Hi Nxp Team,
I have gone through the user manual of RAPPID tool and fallowed the below steps
1. Drag and drop the RBF file o the Evaluvation board
2.reset the EVAL board(connected the S32K144 Eval board with USB)
3. open the Rappid tool
4.load the rbl file (given in the example project of S32K_bootloader ,edited the path in the rbl file)
5. tool updated the all the configuration details and click on the "start the bootloader"
but it is not programmed , it is showing error "loss communication with CCP MCU, please cycle power and try again" and "operation has timed out".
I have tried with reset the controller and tried , but still getting same error.
for the application download also, manually i have set the configuration details and and disable the "BAM status" , tried to flash the Timer_test.hex file ,still it is showing same error.
find the attached errors images and please let me know the solution.
Gopi
stanish
please check this thread:
https://community.nxp.com/thread/469590
Stan
