PWM on GPIO Pins
PWM on GPIO Pins
AnilKumar409
Whenever any particular GPIO pin goes high make PWM with duty cycle of 10% on GPIO pin goes Low. How to  create this project. I need help to proceed.
Tags (2)
AnilKumar409
dear @davidtosenovjan ,
I'm using S32K144 EVB. Yeah dedicated modules are there but why can't we generate PWM on any particular GPIO pin that we are going to use.
davidtosenovjan
Could you clarify used device? And why you want to use GPIO, when you have dedicated modules for this function available (FlexIO or FTM)?
