PWM Input Capture - EMIOS ICU Bus A Configuration Error
2,932件の閲覧回数
Dev15
Hello Team,
We are trying to configure PWM output and PWM input in S32k SDK configuration tool in non Autosar mode.
Following are the pin configurations used for output & input
Output - 8 channels
Input - 1 Channel
PWM Output
PTD16 --> eMIOS_0_CH[1]_G
PTD15 --> eMIOS_1_CH[14]_H
PTE8 --> eMIOS_0_CH[6]_G
PTB5 --> eMIOS_0_CH[5]_G
PTB17 --> eMIOS_1_CH[7]_H
PTB16 --> eMIOS_0_CH[4]_G
PTB15 --> eMIOS_0_CH[3]_G
PTB14 --> eMIOS_0_CH[2]_G
PTB13 --> eMIOS_0_CH[1]_G
PTB12 --> eMIOS_0_CH[0]_X
PTA2 --> eMIOS_1_CH[19]_Y
PWM Input
PTB4 ----> eMIOS_1_CH[10]_H
We are getting error during generation after configuring both pwm input & outputs successfully.
Please find the attached project & error screen shot and help to resolve the same.
Thank you
2 返答(返信)
2,890件の閲覧回数
Senlent
Hi@Dev15
you should create a new clock source for Emios_Icu
for example:
2,853件の閲覧回数
Dev15
@Senlent ,
Thank you for the info. We have configured separate clock source for PWM input channel as suggested.
We are not seeing any generation errors now.
