PMSM motor parameters
1,029 次查看
ZooTech
In the S32K344 BLDC/PMSM Development Kit | NXP Semiconductors following application could you specify the motor parameters of the specified PMSM motor like stator resistance, Ld, Lq and so on ?
2 回复数
1,005 次查看
petervlna
The devkit info and the examples can be found here:
https://www.nxp.com/design/design-center/development-boards-and-designs/MCSPTE1AK344
and
https://community.nxp.com/t5/S32K-Knowledge-Base/S32K3-Motor-control-SW-examples/ta-p/1804577
regarding the motor:
Low-Cost PM motor—3-phase PM motor equipped with Hall sensor, 24 VDC, 9000 RPM, 95 W, 42BLY3A78-24110
The parameters can be found in MCAT in application in the tab "parameters".
Peter
1,011 次查看
petervlna
Let me ask motor control team and I will come back to you ASAP.
Peter
