PIT TRGMUX
PIT TRGMUX
935 次查看
enthuCutlet
I have 8 channels configured on ADC0 and 3 channels configured on ADC1. Can I use one PIT channel(PIT0 CH0) to trigger 2 TRGMUX hardware input which in turn trigger ADC0 and ADC1 respectively. Will this start parallel conv of ADC0 and 1.
1 回复
913 次查看
Robin_Shen
I have configured TRGMUX on S32K1 to select the same Hardware Input for two different Hardware Output. So I think this is also feasible on S32K3.
You can test if it works.
Robin
