The Secure NVM mapping(FULL_MEM) described in HSE FW install for S32K3xx.pdf is as follows:
HSE data flash is 160KB,APP data flash is 88KB,total : 160KB+88KB=248KB
However, the dflash allocation described in S32K3XXRM.pdf is as follows:
The total size of dflash is 128KB
Why are the Dflash sizes mentioned in the two documents different?
Note: I am using the HSE firmware version HSE_FW_S32K344_0_2_55_0_S2502.exe
