OSIF_MutexLock in ISR
1,615件の閲覧回数
赵子成
Hi, everyone,
I use the SDK 3.0.0, Can I use the API OSIF_MutexLock and OSIF_MutexUnlock in ISR.
If not, how can I lock and unlock the shared resource in ISR?
Thanks very much.
1,552件の閲覧回数
Alexis_A
This functions can't be used in an ISR, you need to use the functions xSemaphoreGiveFromISR to release the semaphore, also I will suggest to not use lock functions in an ISR since the IRQ needs to be the shortest possible.
The usual approach is to use a semaphore/mutex take in the task to lock a peripheral or coordinate the tasks and use the give in the ISR to release the peripheral.
Alexis Andalon
