Nxp S32k312 CAN bit timing parameters Issue
ソリューションへジャンプ
1,205件の閲覧回数
Anitha7
Hi, @lukaszadrapa
We are using the FlexCAN0 module for CAN communication. To configure the baud rate, we are using bit timing parameters.
Configuration Details
DeviceS32K3xx - CAN FDfpe_clk [MHz]40
TransceiverTJA1046bitrate [kbps]500
propTXRX [ns]150bitrate FD [kbps]2000
bus length [m]40samp. point [%]90
Our requirement is to achieve a tolerance of ≤ 0.4% for the following parameters:
1. Nominal Bitrate: 500 kbps
  • Prescaler: 4
  • PropSeg: 7
  • PhaseSeg1: 10
  • PhaseSeg2: 2
  • RJW: 2
2. Data Bitrate (for BRS): 2000 kbps
  • Prescaler: 1
  • PropSeg: 7
  • PhaseSeg1: 6
  • PhaseSeg2: 6
  • RJW: 6
Issue Description
The CAN communication works correctly without Bit Rate Switching (BRS). However, when BRS is enabled, we encounter TX errors.
We are using an FXOSC input clock of 40 MHz for the CAN module.
Could you please help us fine-tune the bit timing parameters to achieve a tolerance ≤ 0.4% with BRS enabled, using the 40 MHz FXOSC input clock?
タグ(2)
1,173件の閲覧回数
PetrS
you can try below tool for CAN bit timing parameter calculation;
https://community.nxp.com/t5/MPC5xxx-Knowledge-Base/MPC5xxx-S32Kxx-LPCxxxx-CAN-CAN-FD-bit-timing-cal...
Also see some hints below...
- If possible, select same prescalers for both nominal and data phases.
- If have TDC enabled, try to disable it as it is not needed for this rates.
- Be sure all node use same CAN protocol (non-ISO vs ISO CANFD).
- Have bus properly terminated.
BR, Petr
1,174件の閲覧回数
PetrS
BR, Petr
%3CLINGO-SUB%20id%3D%22lingo-sub-2169707%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENxp%20S32k312%20CAN%E3%83%93%E3%83%83%E3%83%88%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2169707%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37795%22%20target%3D%22_blank%22%3E%40lukaszadrapa%3C%2FA%3E%3C%2FP%3E%3CP%3ECAN%20%E9%80%9A%E4%BF%A1%E3%81%AB%E3%81%AF%3CSTRONG%3EFlexCAN0%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%3CSTRONG%3E%E3%83%93%E3%83%83%E3%83%88%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%3C%2FSTRONG%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1974869213%22%20id%3D%22toc-hId-1999685236%22%3E%E6%A7%8B%E6%88%90%E3%81%AE%E8%A9%B3%E7%B4%B0%3C%2FH3%3E%3CTABLE%20width%3D%22438.124981880188px%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22122.292px%22%3E%3CSTRONG%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%22133.523px%22%3E%3CSTRONG%3ES32K3xx%20-%20CAN%20FD%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%22132.367px%22%3E%3CSTRONG%3Efpe_clk%20%5BMHz%5D%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%2249.3371px%22%3E%3CSTRONG%3E40%3C%2FSTRONG%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22122.292px%22%3E%3CSTRONG%3E%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%22133.523px%22%3E%3CSTRONG%3ETJA1046%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%22132.367px%22%3E%3CSTRONG%3E%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%20%5Bkbps%5D%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%2249.3371px%22%3E%3CSTRONG%3E500%3C%2FSTRONG%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22122.292px%22%3E%3CSTRONG%3E%E3%83%97%E3%83%AD%E3%83%83%E3%83%97TXRX%20%5Bns%5D%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%22133.523px%22%3E%3CSTRONG%3E150%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%22132.367px%22%3E%3CSTRONG%3E%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88FD%20%5Bkbps%5D%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%2249.3371px%22%3E%3CSTRONG%3E2000%3C%2FSTRONG%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22122.292px%22%3E%3CSTRONG%3E%E3%83%90%E3%82%B9%E3%81%AE%E9%95%B7%E3%81%95%20%5Bm%5D%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%22133.523px%22%3E%3CSTRONG%3E40%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%22132.367px%22%3E%3CSTRONG%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%80%82%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%5B%EF%BC%85%5D%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%2249.3371px%22%3E%3CSTRONG%3E90%3C%2FSTRONG%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3E%E5%BD%93%E7%A4%BE%E3%81%AE%E8%A6%81%E4%BB%B6%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%3CSTRONG%3E0.4%25%20%E4%BB%A5%E4%B8%8B%E3%81%AE%E8%A8%B1%E5%AE%B9%E5%B7%AE%3C%2FSTRONG%3E%E3%82%92%E9%81%94%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CH4%20id%3D%22toc-hId--1629536609%22%20id%3D%22toc-hId--1604720586%22%3E1.%3CSTRONG%3E%E5%85%AC%E7%A7%B0%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%3A%20500%20kbps%3C%2FSTRONG%3E%3C%2FH4%3E%3CUL%3E%3CLI%3E%3CP%3E%E3%83%97%E3%83%AA%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%A9%3A%204%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%83%97%E3%83%AD%E3%83%83%E3%83%97%E3%82%BB%E3%82%B0%3A%207%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA1%3A%2010%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%882%3A%202%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ERJW%3A%202%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CH4%20id%3D%22toc-hId-857976224%22%20id%3D%22toc-hId-882792247%22%3E2.%3CSTRONG%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%EF%BC%88BRS%E7%94%A8%EF%BC%89%EF%BC%9A2000%20kbps%3C%2FSTRONG%3E%3C%2FH4%3E%3CUL%3E%3CLI%3E%3CP%3E%E3%83%97%E3%83%AA%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%A9%3A%201%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%83%97%E3%83%AD%E3%83%83%E3%83%97%E3%82%BB%E3%82%B0%3A%207%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA1%3A%206%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA2%3A%206%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ERJW%3A%206%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CH3%20id%3D%22toc-hId-847473120%22%20id%3D%22toc-hId-872289143%22%3E%E5%95%8F%E9%A1%8C%E3%81%AE%E8%AA%AC%E6%98%8E%3C%2FH3%3E%3CP%3ECAN%20%E9%80%9A%E4%BF%A1%E3%81%AF%3CSTRONG%3E%E3%80%81%E3%83%93%E3%83%83%E3%83%88%20%E3%83%AC%E3%83%BC%E3%83%88%20%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%83%B3%E3%82%B0%20(BRS)%3C%2FSTRONG%3E%E3%81%AA%E3%81%97%E3%81%A7%E3%82%82%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81BRS%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%20%3CSTRONG%3ETX%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%3C%2FSTRONG%3E%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ECAN%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AB%E3%81%AF%3CSTRONG%3E40%20MHz%20%E3%81%AE%20FXOSC%20%E5%85%A5%E5%8A%9B%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E40%20MHz%20FXOSC%20%E5%85%A5%E5%8A%9B%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%20%3CSTRONG%3EBRS%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%9F%E7%8A%B6%E6%85%8B%3C%2FSTRONG%3E%E3%81%A7%E3%80%81%3CSTRONG%3E%E8%A8%B1%E5%AE%B9%E8%AA%A4%E5%B7%AE%20%E2%89%A4%200.4%25%3C%2FSTRONG%3E%E3%82%92%E9%81%94%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%83%93%E3%83%83%E3%83%88%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E5%BE%AE%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E3%81%8A%E6%89%8B%E4%BC%9D%E3%81%84%E3%82%92%E3%81%8A%E9%A1%98%E3%81%84%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2169744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Nxp%20S32k312%20CAN%20bit%20timing%20parameters%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2169744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3ECAN%20%E3%83%93%E3%83%83%E3%83%88%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AE%E8%A8%88%E7%AE%97%E3%81%AB%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E8%A9%A6%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMPC5xxx-Knowledge-Base%2FMPC5xxx-S32Kxx-LPCxxxx-CAN-CAN-FD-bit-timing-calculation%2Fta-p%2F1119319%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMPC5xxx-Knowledge-Base%2FMPC5xxx-S32Kxx-LPCxxxx-CAN-CAN-FD-%E3%83%93%E3%83%83%E3%83%88%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E8%A8%88%E7%AE%97%2Fta-p%2F1119319%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%92%E3%83%B3%E3%83%88%E3%82%82%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84...%3CBR%20%2F%3E%20-%20%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E5%85%AC%E7%A7%B0%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E3%81%A8%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AB%E5%90%8C%E3%81%98%E3%83%97%E3%83%AA%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%A9%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E-%20TDC%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AB%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E-%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%8E%E3%83%BC%E3%83%89%E3%81%8C%E5%90%8C%E3%81%98%20CAN%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20(%E9%9D%9E%20ISO%20%E3%81%A8%20ISO%20CANFD)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20-%20%E3%83%90%E3%82%B9%E3%82%92%E9%81%A9%E5%88%87%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%95%E3%81%9B%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%E3%80%81%E3%83%9A%E3%83%88%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E
