NXPS32k144EVB issue
NXPS32k144EVB issue
540 次查看
Sami2098
Hello
i am using nxps32k144evb board when i try to flash code using s32 design studio following issue occure and if i press retry same window again appear one this i notices when i connect jflash
Connecting ... - Connecting via USB to probe/ programmer device 0 - Probe/ Programmer firmware: J-Link V9 compiled May 7 2021 16:26:12 - Probe/ Programmer S/N: 69408845 - Device "S32K144" selected. - Target interface speed: 4000 kHz (Fixed) - VTarget = 3.288V - InitTarget() start - SWD selected. Executing JTAG -> SWD switching sequence. - Protection bytes in flash at addr. 0x400 - 0x40F indicate that readout protection is set. For debugger connection the device needs to be unsecured. Note: Unsecuring will trigger a mass erase of the internal flash. - Executing default behavior previously saved in the registry. - Device will be unsecured now. - Timeout while unsecuring device. Erase never stops. - InitTarget() end - Took 2.15s - Found SW-DP with ID 0x2BA01477 - DPIDR: 0x2BA01477 - CoreSight SoC-400 or earlier - Scanning AP map to find all available APs - AP[2]: Stopped AP scan as end of AP map has been reached - AP[0]: AHB-AP (IDR: 0x24770011) - AP[1]: JTAG-AP (IDR: 0x001C0000) - Iterating through AP map to find AHB-AP to use - AP[0]: Skipped. Could not read CPUID register - AP[1]: Skipped. Not an AHB-AP - Attach to CPU failed. Executing connect under reset. - DPIDR: 0x2BA01477 - CoreSight SoC-400 or earlier - Scanning AP map to find all available APs - AP[2]: Stopped AP scan as end of AP map has been reached - AP[0]: AHB-AP (IDR: 0x24770011) - AP[1]: JTAG-AP (IDR: 0x001C0000) - Iterating through AP map to find AHB-AP to use - AP[0]: Skipped. Could not read CPUID register - AP[1]: Skipped. Not an AHB-AP - Could not find core in Coresight setup - InitTarget() start - SWD selected. Executing JTAG -> SWD switching sequence. - Protection bytes in flash at addr. 0x400 - 0x40F indicate that readout protection is set. For debugger connection the device needs to be unsecured. Note: Unsecuring will trigger a mass erase of the internal flash. - Executing default behavior previously saved in the registry. - Device will be unsecured now. - Timeout while unsecuring device. Erase never stops. - InitTarget() end - Took 2.15s - Found SW-DP with ID 0x2BA01477 - DPIDR: 0x2BA01477 - CoreSight SoC-400 or earlier - Scanning AP map to find all available APs - AP[2]: Stopped AP scan as end of AP map has been reached - AP[0]: AHB-AP (IDR: 0x24770011) - AP[1]: JTAG-AP (IDR: 0x001C0000) - Iterating through AP map to find AHB-AP to use - AP[0]: Skipped. Could not read CPUID register - AP[1]: Skipped. Not an AHB-AP - Attach to CPU failed. Executing connect under reset. - DPIDR: 0x2BA01477 - CoreSight SoC-400 or earlier - Scanning AP map to find all available APs - AP[2]: Stopped AP scan as end of AP map has been reached - AP[0]: AHB-AP (IDR: 0x24770011) - AP[1]: JTAG-AP (IDR: 0x001C0000) - Iterating through AP map to find AHB-AP to use - AP[0]: Skipped. Could not read CPUID register - AP[1]: Skipped. Not an AHB-AP - Could not find core in Coresight setup - ERROR: Failed to connect. Could not establish a connection to target. - ERROR: Connect failed
1 回复
471 次查看
Robin_Shen
Most likely causes:
  1. Flash security is set in the Flash Configuration Field.
    On S32K144, the security state comes from the Flash Secure Register FSEC , which is loaded from the flash security byte in the Flash Configuration Field at reset; the device is secure when SEC is not 0b10 .
  2. Mass erase is required but is being blocked.
    S32K144 can normally be unsecured by Mass Erase or Verify Backdoor Access Key , if those paths are enabled by the relevant FSEC bits . However, if CSEc was enabled by partitioning ,  mass erase is blocked , even if mass erase appears enabled in MEEN/MEEM . https://community.nxp.com/t5/S32K/Device-is-secure/td-p/1744921
  3. If CSEc is enabled, recovery requires the CSEc debug-auth flow.
    The documented recovery path is to destroy the CSEc partition using CMD_DBG_CHAL and CMD_DBG_AUTH with knowledge of MASTER_ECU_KEY ; after that, mass erase becomes available again . If the key is not known and the device is secured with CSEc blocking mass erase, there is no recovery path for that device . https://community.nxp.com/t5/S32K/Erased-whole-flash-of-the-S32K144/td-p/2036891
What I would try, in order:
  • If this board ever ran CSEc / secure boot / EEPROM-partitioning examples: assume CSEc partitioning may be involved. Use the MASTER_ECU_KEY flow if you have the key: CMD_DBG_CHAL → CMD_DBG_AUTH → destroy CSEc partition → mass erase.
  • If CSEc was not intentionally enabled: try a basic J-Link recovery once more with very low SWD speed, power-cycle, reset asserted/released correctly, and unlock Kinetis . This only works when mass erase is actually allowed;  unlock Kinetis should work if mass erase is enabled. https://community.nxp.com/t5/S32K/S32K148-Unsecurity/m-p/1182938
  • If you still have any way to connect using a PEmicro/OpenSDA-style flow: it may be worth trying because NXP notes that PEmicro tools erase using Erase Flash Block , while J-Link uses mass erase when loading a new project; that distinction can matter when CSEc blocks mass erase.
  • If reset is physically held low: fix that first. A target stuck in reset can also prevent core attach, but your log’s repeated security/mass-erase timeout is the stronger clue.
Bottom line: this looks like a security/CSEc/mass-erase-blocked condition , not a normal connection-speed problem. If CSEc is enabled and you do not have the MASTER_ECU_KEY , the practical answer is usually to replace the MCU.
The decisive branch is whether CSEc partitioning was enabled: with the MASTER_ECU_KEY , destroy the CSEc partition and erase; without it, the secured S32K144 is likely unrecoverable.
Robin
%3CLINGO-SUB%20id%3D%22lingo-sub-2387593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENXPS32k144EVB%20%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2387593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20NXPS32K144EVB%20%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%8C%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20S32%20Design%20Studio%20%E7%83%A7%E5%BD%95%E4%BB%A3%E7%A0%81%E6%97%B6%EF%BC%8C%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%97%AE%E9%A2%98%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E7%82%B9%E5%87%BB%E9%87%8D%E8%AF%95%EF%BC%8C%E5%90%8C%E6%A0%B7%E7%9A%84%E7%AA%97%E5%8F%A3%E4%BC%9A%E5%86%8D%E6%AC%A1%E5%87%BA%E7%8E%B0%E3%80%82%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%EF%BC%8C%E5%BD%93%E6%88%91%E8%BF%9E%E6%8E%A5%20JFlash%20%E6%97%B6%E4%B9%9F%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sami2098_0-1782720837787.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sami2098_0-1782720837787.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F390553iDDA8045A802CB9BE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sami2098_0-1782720837787.png%22%20alt%3D%22Sami2098_0-1782720837787.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%AD%A3%E5%9C%A8%E8%BF%9E%E6%8E%A5...%20-%20%E9%80%9A%E8%BF%87%20USB%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%8E%A2%E9%92%88%2F%E7%BC%96%E7%A8%8B%E5%99%A8%E8%AE%BE%E5%A4%87%200%20-%20%E6%8E%A2%E9%92%88%2F%E7%BC%96%E7%A8%8B%E5%99%A8%E5%9B%BA%E4%BB%B6%EF%BC%9AJ-Link%20V9%EF%BC%8C%E7%BC%96%E8%AF%91%E4%BA%8E%202021%20%E5%B9%B4%205%20%E6%9C%88%207%20%E6%97%A5%2016%3A26%3A12%20-%20%E6%8E%A2%E9%92%88%2F%E7%BC%96%E7%A8%8B%E5%99%A8%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9A69408845%20-%20%E5%B7%B2%E9%80%89%E6%8B%A9%E8%AE%BE%E5%A4%87%E2%80%9CS32K144%E2%80%9D%E3%80%82-%20%E7%9B%AE%E6%A0%87%E6%8E%A5%E5%8F%A3%E9%80%9F%E5%BA%A6%EF%BC%9A4000%20kHz%EF%BC%88%E5%9B%BA%E5%AE%9A%EF%BC%89%20-%20VTarget%20%3D%203.288V%20-%20InitTarget()%20%E5%BC%80%E5%A7%8B%20-%20%E5%B7%B2%E9%80%89%E6%8B%A9%20SWD%E3%80%82%E6%89%A7%E8%A1%8C%20JTAG%20-%26gt%3B%20SWD%20%E5%88%87%E6%8D%A2%E5%BA%8F%E5%88%97%E3%80%82-%3CSTRONG%3E%E9%97%AA%E5%AD%98%E5%9C%B0%E5%9D%80%200x400%20-%200x40F%20%E5%A4%84%E7%9A%84%E4%BF%9D%E6%8A%A4%E5%AD%97%E8%8A%82%E8%A1%A8%E7%A4%BA%E5%B7%B2%E8%AE%BE%E7%BD%AE%E8%AF%BB%E5%8F%96%E4%BF%9D%E6%8A%A4%E3%80%82%3C%2FSTRONG%3E%E8%A6%81%E8%BF%9E%E6%8E%A5%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%8C%E8%AE%BE%E5%A4%87%E5%BF%85%E9%A1%BB%E5%A4%84%E4%BA%8E%E9%9D%9E%E5%8A%A0%E5%AF%86%E7%8A%B6%E6%80%81%E3%80%82%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%A7%A3%E9%99%A4%E5%AE%89%E5%85%A8%E8%AE%BE%E7%BD%AE%E5%B0%86%E8%A7%A6%E5%8F%91%E5%AF%B9%E5%86%85%E9%83%A8%E9%97%AA%E5%AD%98%E7%9A%84%E5%A4%A7%E8%A7%84%E6%A8%A1%E6%93%A6%E9%99%A4%E3%80%82-%20%E6%89%A7%E8%A1%8C%E4%B9%8B%E5%89%8D%E4%BF%9D%E5%AD%98%E5%9C%A8%E6%B3%A8%E5%86%8C%E8%A1%A8%E4%B8%AD%E7%9A%84%E9%BB%98%E8%AE%A4%E8%A1%8C%E4%B8%BA%E3%80%82-%20%E8%AE%BE%E5%A4%87%E7%8E%B0%E5%9C%A8%E5%B0%86%E5%A4%84%E4%BA%8E%E4%B8%8D%E5%AE%89%E5%85%A8%E7%8A%B6%E6%80%81%E3%80%82-%20%E8%A7%A3%E9%99%A4%E8%AE%BE%E5%A4%87%E5%AE%89%E5%85%A8%E4%BF%9D%E6%8A%A4%E6%97%B6%E8%B6%85%E6%97%B6%E3%80%82%E6%8A%B9%E9%99%A4%E6%B0%B8%E6%97%A0%E6%AD%A2%E5%A2%83%E3%80%82-%20InitTarget()%20%E7%BB%93%E6%9D%9F%20-%20%E8%80%97%E6%97%B6%202.15%20%E7%A7%92%20-%20%E6%89%BE%E5%88%B0%20ID%20%E4%B8%BA%200x2BA01477%20%E7%9A%84%20SW-DP%20-%20DPIDR%EF%BC%9A0x2BA01477%20-%20CoreSight%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%20-%20%E6%AD%A3%E5%9C%A8%E6%89%AB%E6%8F%8F%20AP%20%E6%98%A0%E5%B0%84%E4%BB%A5%E6%9F%A5%E6%89%BE%E6%89%80%E6%9C%89%E5%8F%AF%E7%94%A8%E7%9A%84%20AP%20-%20AP%5B2%5D%EF%BC%9A%E5%B7%B2%E5%88%B0%E8%BE%BE%20AP%20%E6%98%A0%E5%B0%84%E7%9A%84%E6%9C%AB%E5%B0%BE%EF%BC%8C%E5%81%9C%E6%AD%A2%20AP%20%E6%89%AB%E6%8F%8F%20-%20AP%5B0%5D%EF%BC%9AAHB-AP%EF%BC%88IDR%EF%BC%9A0x24770011%EF%BC%89%20-%20AP%5B1%5D%EF%BC%9AJTAG-AP%EF%BC%88IDR%EF%BC%9A0x001C0000%EF%BC%89%20-%20%E6%AD%A3%E5%9C%A8%E9%81%8D%E5%8E%86%20AP%20%E6%98%A0%E5%B0%84%E4%BB%A5%E6%9F%A5%E6%89%BE%E8%A6%81%E4%BD%BF%E7%94%A8%E7%9A%84%20AHB-AP%20-%20AP%5B0%5D%EF%BC%9A%E5%B7%B2%E8%B7%B3%E8%BF%87%E3%80%82%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%20-%20AP%5B1%5D%3A%20%E5%B7%B2%E8%B7%B3%E8%BF%87%E3%80%82%E9%9D%9EAHB-AP%20-%20%E8%BF%9E%E6%8E%A5%E5%88%B0CPU%E5%A4%B1%E8%B4%A5%E3%80%82%E6%89%A7%E8%A1%8CRESET%E5%90%8E%E7%9A%84%E8%BF%9E%E6%8E%A5%E6%93%8D%E4%BD%9C%E3%80%82-%20DPIDR%EF%BC%9A0x2BA01477%20-%20CoreSight%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%20-%20%E6%AD%A3%E5%9C%A8%E6%89%AB%E6%8F%8F%20AP%20%E5%9C%B0%E5%9B%BE%E4%BB%A5%E6%9F%A5%E6%89%BE%E6%89%80%E6%9C%89%E5%8F%AF%E7%94%A8%E7%9A%84%20AP%20-%20AP%5B2%5D%EF%BC%9A%E5%B7%B2%E5%88%B0%E8%BE%BE%20AP%20%E5%9C%B0%E5%9B%BE%E6%9C%AB%E5%B0%BE%EF%BC%8C%E5%B7%B2%E5%81%9C%E6%AD%A2%20AP%20%E6%89%AB%E6%8F%8F%20-%20AP%5B0%5D%EF%BC%9AAHB-AP%EF%BC%88IDR%EF%BC%9A0x24770011%EF%BC%89%20-%20AP%5B1%5D%EF%BC%9AJTAG-AP%EF%BC%88IDR%EF%BC%9A0x001C0000%EF%BC%89%20-%20%E6%AD%A3%E5%9C%A8%E9%81%8D%E5%8E%86%20AP%20%E5%9C%B0%E5%9B%BE%E4%BB%A5%E6%9F%A5%E6%89%BE%E8%A6%81%E4%BD%BF%E7%94%A8%E7%9A%84%20AHB-AP%20-%20AP%5B0%5D%EF%BC%9A%E5%B7%B2%E8%B7%B3%E8%BF%87%E3%80%82%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%20-%20AP%5B1%5D%3A%20%E5%B7%B2%E8%B7%B3%E8%BF%87%E3%80%82%E4%B8%8D%E6%98%AF%20AHB-AP%20-%20%E5%9C%A8%20Coresight%20%E8%AE%BE%E7%BD%AE%E4%B8%AD%E6%89%BE%E4%B8%8D%E5%88%B0%E6%A0%B8%E5%BF%83%20-%20InitTarget()%20%E5%BC%80%E5%A7%8B%20-%20%E5%B7%B2%E9%80%89%E6%8B%A9%20SWD%E3%80%82%E6%89%A7%E8%A1%8C%20JTAG%20-%26gt%3B%20SWD%20%E5%88%87%E6%8D%A2%E5%BA%8F%E5%88%97%E3%80%82-%20%E5%9C%B0%E5%9D%80%E5%A4%84%E7%9A%84%E9%97%AA%E5%AD%98%E4%B8%AD%E7%9A%84%E4%BF%9D%E6%8A%A4%E5%AD%97%E8%8A%82%E3%80%820x400%20-%200x40F%20%E8%A1%A8%E7%A4%BA%E5%B7%B2%E8%AE%BE%E7%BD%AE%E8%AF%BB%E5%8F%96%E4%BF%9D%E6%8A%A4%E3%80%82%E8%A6%81%E8%BF%9E%E6%8E%A5%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%8C%E8%AE%BE%E5%A4%87%E5%BF%85%E9%A1%BB%E5%A4%84%E4%BA%8E%E9%9D%9E%E5%8A%A0%E5%AF%86%E7%8A%B6%E6%80%81%E3%80%82%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%A7%A3%E9%99%A4%E5%AE%89%E5%85%A8%E8%AE%BE%E7%BD%AE%E5%B0%86%E8%A7%A6%E5%8F%91%E5%AF%B9%E5%86%85%E9%83%A8%E9%97%AA%E5%AD%98%E7%9A%84%E5%A4%A7%E8%A7%84%E6%A8%A1%E6%93%A6%E9%99%A4%E3%80%82-%20%E6%89%A7%E8%A1%8C%E4%B9%8B%E5%89%8D%E4%BF%9D%E5%AD%98%E5%9C%A8%E6%B3%A8%E5%86%8C%E8%A1%A8%E4%B8%AD%E7%9A%84%E9%BB%98%E8%AE%A4%E8%A1%8C%E4%B8%BA%E3%80%82-%20%E8%AE%BE%E5%A4%87%E7%8E%B0%E5%9C%A8%E5%B0%86%E5%A4%84%E4%BA%8E%E4%B8%8D%E5%AE%89%E5%85%A8%E7%8A%B6%E6%80%81%E3%80%82-%20%E8%A7%A3%E9%99%A4%E8%AE%BE%E5%A4%87%E5%AE%89%E5%85%A8%E4%BF%9D%E6%8A%A4%E6%97%B6%E8%B6%85%E6%97%B6%E3%80%82%E6%8A%B9%E9%99%A4%E6%B0%B8%E6%97%A0%E6%AD%A2%E5%A2%83%E3%80%82-%20InitTarget()%20%E7%BB%93%E6%9D%9F%20-%20%E8%80%97%E6%97%B6%202.15%20%E7%A7%92%20-%20%E6%89%BE%E5%88%B0%20ID%20%E4%B8%BA%200x2BA01477%20%E7%9A%84%20SW-DP%20-%20DPIDR%EF%BC%9A0x2BA01477%20-%20CoreSight%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%20-%20%E6%AD%A3%E5%9C%A8%E6%89%AB%E6%8F%8F%20AP%20%E6%98%A0%E5%B0%84%E4%BB%A5%E6%9F%A5%E6%89%BE%E6%89%80%E6%9C%89%E5%8F%AF%E7%94%A8%E7%9A%84%20AP%20-%20AP%5B2%5D%EF%BC%9A%E5%B7%B2%E5%88%B0%E8%BE%BE%20AP%20%E6%98%A0%E5%B0%84%E7%9A%84%E6%9C%AB%E5%B0%BE%EF%BC%8C%E5%81%9C%E6%AD%A2%20AP%20%E6%89%AB%E6%8F%8F%20-%20AP%5B0%5D%EF%BC%9AAHB-AP%EF%BC%88IDR%EF%BC%9A0x24770011%EF%BC%89%20-%20AP%5B1%5D%EF%BC%9AJTAG-AP%EF%BC%88IDR%EF%BC%9A0x001C0000%EF%BC%89%20-%20%E6%AD%A3%E5%9C%A8%E9%81%8D%E5%8E%86%20AP%20%E6%98%A0%E5%B0%84%E4%BB%A5%E6%9F%A5%E6%89%BE%E8%A6%81%E4%BD%BF%E7%94%A8%E7%9A%84%20AHB-AP%20-%20AP%5B0%5D%EF%BC%9A%E5%B7%B2%E8%B7%B3%E8%BF%87%E3%80%82%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%20-%20AP%5B1%5D%3A%20%E5%B7%B2%E8%B7%B3%E8%BF%87%E3%80%82%E9%9D%9EAHB-AP%20-%20%E8%BF%9E%E6%8E%A5%E5%88%B0CPU%E5%A4%B1%E8%B4%A5%E3%80%82%E6%89%A7%E8%A1%8CRESET%E5%90%8E%E7%9A%84%E8%BF%9E%E6%8E%A5%E6%93%8D%E4%BD%9C%E3%80%82-%20DPIDR%EF%BC%9A0x2BA01477%20-%20CoreSight%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%20-%20%E6%AD%A3%E5%9C%A8%E6%89%AB%E6%8F%8F%20AP%20%E5%9C%B0%E5%9B%BE%E4%BB%A5%E6%9F%A5%E6%89%BE%E6%89%80%E6%9C%89%E5%8F%AF%E7%94%A8%E7%9A%84%20AP%20-%20AP%5B2%5D%EF%BC%9A%E5%B7%B2%E5%88%B0%E8%BE%BE%20AP%20%E5%9C%B0%E5%9B%BE%E6%9C%AB%E5%B0%BE%EF%BC%8C%E5%B7%B2%E5%81%9C%E6%AD%A2%20AP%20%E6%89%AB%E6%8F%8F%20-%20AP%5B0%5D%EF%BC%9AAHB-AP%EF%BC%88IDR%EF%BC%9A0x24770011%EF%BC%89%20-%20AP%5B1%5D%EF%BC%9AJTAG-AP%EF%BC%88IDR%EF%BC%9A0x001C0000%EF%BC%89%20-%20%E6%AD%A3%E5%9C%A8%E9%81%8D%E5%8E%86%20AP%20%E5%9C%B0%E5%9B%BE%E4%BB%A5%E6%9F%A5%E6%89%BE%E8%A6%81%E4%BD%BF%E7%94%A8%E7%9A%84%20AHB-AP%20-%20AP%5B0%5D%EF%BC%9A%E5%B7%B2%E8%B7%B3%E8%BF%87%E3%80%82%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%20-%20AP%5B1%5D%3A%20%E5%B7%B2%E8%B7%B3%E8%BF%87%E3%80%82%E4%B8%8D%E6%98%AF%20AHB-AP%20-%20%E5%9C%A8%20Coresight%20%E8%AE%BE%E7%BD%AE%E4%B8%AD%E6%89%BE%E4%B8%8D%E5%88%B0%E6%A0%B8%E5%BF%83%20-%20%E9%94%99%E8%AF%AF%EF%BC%9A%E8%BF%9E%E6%8E%A5%E5%A4%B1%E8%B4%A5%E3%80%82%E6%97%A0%E6%B3%95%E4%B8%8E%E7%9B%AE%E6%A0%87%E5%BB%BA%E7%AB%8B%E8%BF%9E%E6%8E%A5%E3%80%82-%20%E9%94%99%E8%AF%AF%EF%BC%9A%E8%BF%9E%E6%8E%A5%E5%A4%B1%E8%B4%A5%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXPS32k144EVB%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%3C%2FP%3E%0A%3CP%20class%3D%22%22%3E%E6%9C%80%E5%8F%AF%E8%83%BD%E7%9A%84%E5%8E%9F%E5%9B%A0%EF%BC%9A%3C%2FP%3E%0A%3COL%20class%3D%22%22%3E%0A%3CLI%20class%3D%22%22%3E%0A%3CP%20class%3D%22%22%3E%3CSTRONG%20class%3D%22%22%3E%E9%97%AA%E5%AD%98%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E8%AE%BE%E7%BD%AE%E5%9C%A8%E9%97%AA%E5%AD%98%E9%85%8D%E7%BD%AE%E5%AD%97%E6%AE%B5%E4%B8%AD%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3E%E5%9C%A8%20S32K144%20%E4%B8%8A%EF%BC%8C%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E7%8A%B6%E6%80%81%E6%9D%A5%E8%87%AA%E9%97%AA%E5%AD%98%E5%AE%89%E5%85%A8%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3EFSEC%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E8%AF%A5%E5%80%BC%E5%9C%A8%20RESET%20%E6%97%B6%E4%BB%8E%E9%97%AA%E5%AD%98%E9%85%8D%E7%BD%AE%E5%AD%97%E6%AE%B5%E4%B8%AD%E7%9A%84%E9%97%AA%E5%AD%98%E5%AE%89%E5%85%A8%E5%AD%97%E8%8A%82%E5%8A%A0%E8%BD%BD%EF%BC%9B%E8%AE%BE%E5%A4%87%E5%9C%A8%E4%BB%A5%E4%B8%8B%E6%83%85%E5%86%B5%E4%B8%8B%E5%A4%84%E4%BA%8E%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E7%8A%B6%E6%80%81%EF%BC%9A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3ESEC%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E4%B8%8D%E6%98%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3E0b10%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%20class%3D%22%22%3E%0A%3CP%20class%3D%22%22%3E%3CSTRONG%20class%3D%22%22%3E%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E6%89%B9%E9%87%8F%E6%93%A6%E9%99%A4%EF%BC%8C%E4%BD%86%E8%AF%A5%E6%93%8D%E4%BD%9C%E8%A2%AB%E9%98%BB%E6%AD%A2%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3ES32K144%20%E9%80%9A%E5%B8%B8%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8B%E6%96%B9%E5%BC%8F%E8%A7%A3%E9%99%A4%E5%AE%89%E5%85%A8%EF%BC%9A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E%E6%89%B9%E9%87%8F%E6%93%A6%E9%99%A4%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%88%96%E8%80%85%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E%E9%AA%8C%E8%AF%81%E5%90%8E%E9%97%A8%E8%AE%BF%E9%97%AE%E5%AF%86%E9%92%A5%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%A6%82%E6%9E%9C%E8%BF%99%E4%BA%9B%E8%B7%AF%E5%BE%84%E5%B7%B2%E7%94%B1%E7%9B%B8%E5%85%B3%E7%B3%BB%E7%BB%9F%E5%90%AF%E7%94%A8%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3EFSEC%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%AF%94%E7%89%B9%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%80%82%E7%84%B6%E8%80%8C%EF%BC%8C%E5%A6%82%E6%9E%9C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3ECSEc%E6%98%AF%E9%80%9A%E8%BF%87%E5%88%86%E5%8C%BA%E5%AE%9E%E7%8E%B0%E7%9A%84%E3%80%82%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%EF%BC%8C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E%E6%89%B9%E9%87%8F%E6%93%A6%E9%99%A4%E5%8A%9F%E8%83%BD%E5%B7%B2%E8%A2%AB%E9%98%BB%E6%AD%A2%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%8D%B3%E4%BD%BF%E6%89%B9%E9%87%8F%E6%93%A6%E9%99%A4%E5%8A%9F%E8%83%BD%E4%BC%BC%E4%B9%8E%E5%B7%B2%E5%90%AF%E7%94%A8%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3EMEEN%2FMEEM%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FDevice-is-secure%2Ftd-p%2F1744921%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FDevice-is-secure%2Ftd-p%2F1744921%3C%2FA%3E%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%20class%3D%22%22%3E%0A%3CP%20class%3D%22%22%3E%3CSTRONG%20class%3D%22%22%3E%E5%A6%82%E6%9E%9C%E5%90%AF%E7%94%A8%E4%BA%86%20CSEc%EF%BC%8C%E5%88%99%E6%81%A2%E5%A4%8D%E9%9C%80%E8%A6%81%20CSEc%20%E8%B0%83%E8%AF%95%E8%AE%A4%E8%AF%81%E6%B5%81%E7%A8%8B%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3E%E5%B7%B2%E8%AE%B0%E5%BD%95%E7%9A%84%E6%81%A2%E5%A4%8D%E8%B7%AF%E5%BE%84%E6%98%AF%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E9%94%80%E6%AF%81%20CSEc%20%E5%88%86%E5%8C%BA%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3ECMD_DBG_CHAL%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%92%8C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3ECMD_DBG_AUTH%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%85%B7%E5%A4%87%E4%BB%A5%E4%B8%8B%E6%96%B9%E9%9D%A2%E7%9A%84%E7%9F%A5%E8%AF%86%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3EMASTER_ECU_KEY%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E4%B9%8B%E5%90%8E%EF%BC%8C%E6%89%B9%E9%87%8F%E6%93%A6%E9%99%A4%E5%8A%9F%E8%83%BD%E5%B0%86%E5%86%8D%E6%AC%A1%E5%8F%AF%E7%94%A8%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%80%82%E5%A6%82%E6%9E%9C%E5%AF%86%E9%92%A5%E6%9C%AA%E7%9F%A5%EF%BC%8C%E4%B8%94%E8%AE%BE%E5%A4%87%E5%90%AF%E7%94%A8%E4%BA%86%20CSEc%20%E5%AE%89%E5%85%A8%E6%9C%BA%E5%88%B6%E4%BB%A5%E9%98%BB%E6%AD%A2%E6%89%B9%E9%87%8F%E6%93%A6%E9%99%A4%EF%BC%8C%E5%88%99%E8%AF%A5%E8%AE%BE%E5%A4%87%E6%97%A0%E6%B3%95%E6%81%A2%E5%A4%8D%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FErased-whole-flash-of-the-S32K144%2Ftd-p%2F2036891%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FErased-whole-flash-of-the-S32K144%2Ftd-p%2F2036891%3C%2FA%3E%3C%2FP%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%20class%3D%22%22%3E%E6%88%91%E4%BC%9A%E6%8C%89%E4%BB%A5%E4%B8%8B%E9%A1%BA%E5%BA%8F%E5%B0%9D%E8%AF%95%EF%BC%9A%3C%2FP%3E%0A%3CUL%20class%3D%22%22%3E%0A%3CLI%20class%3D%22%22%3E%3CSTRONG%20class%3D%22%22%3E%E5%A6%82%E6%9E%9C%E8%AF%A5%E6%9D%BF%E6%9B%BE%E7%BB%8F%E8%BF%90%E8%A1%8C%E8%BF%87%20CSEc%20%2F%20%E5%AE%89%E5%85%A8%E5%90%AF%E5%8A%A8%20%2F%20EEPROM%20%E5%88%86%E5%8C%BA%E7%A4%BA%E4%BE%8B%EF%BC%9A%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%81%87%E8%AE%BE%E5%8F%AF%E8%83%BD%E6%B6%89%E5%8F%8A%20CSEc%20%E5%88%86%E5%8C%BA%E3%80%82%E4%BD%BF%E7%94%A8%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3EMASTER_ECU_KEY%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E6%9C%89%E5%AF%86%E9%92%A5%EF%BC%8C%E6%B5%81%E7%A8%8B%E5%A6%82%E4%B8%8B%EF%BC%9A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3ECMD_DBG_CHAL%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E2%86%92%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3ECMD_DBG_AUTH%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E2%86%92%20%E9%94%80%E6%AF%81%20CSEc%20%E5%88%86%E5%8C%BA%20%E2%86%92%20%E6%89%B9%E9%87%8F%E6%93%A6%E9%99%A4%E3%80%82%3C%2FLI%3E%0A%3CLI%20class%3D%22%22%3E%3CSTRONG%20class%3D%22%22%3E%E5%A6%82%E6%9E%9C%E5%B9%B6%E9%9D%9E%E6%9C%89%E6%84%8F%E5%90%AF%E7%94%A8%20CSEc%EF%BC%9A%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%86%8D%E6%AC%A1%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E9%9D%9E%E5%B8%B8%E4%BD%8E%E7%9A%84SWD%E9%80%9F%E5%BA%A6%E8%BF%9B%E8%A1%8C%E5%9F%BA%E6%9C%AC%E7%9A%84J-Link%E6%81%A2%E5%A4%8D%EF%BC%8C%E6%96%AD%E7%94%B5%E9%87%8D%E5%90%AF%EF%BC%8CRESET%E5%B7%B2%E6%AD%A3%E7%A1%AE%E9%92%B3%E4%BD%8D%2F%E9%87%8A%E6%94%BE%EF%BC%8C%E5%B9%B6%E4%B8%94%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3Eunlock%20Kinetis%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%80%82%E5%8F%AA%E6%9C%89%E5%9C%A8%E5%85%81%E8%AE%B8%E6%89%B9%E9%87%8F%E6%93%A6%E9%99%A4%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E8%BF%99%E7%A7%8D%E6%96%B9%E6%B3%95%E6%89%8D%E6%9C%89%E6%95%88%EF%BC%9B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3Eunlock%20Kinetis%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%A6%82%E6%9E%9C%E5%90%AF%E7%94%A8%E6%89%B9%E9%87%8F%E6%93%A6%E9%99%A4%E5%8A%9F%E8%83%BD%EF%BC%8C%E5%BA%94%E8%AF%A5%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K148-Unsecurity%2Fm-p%2F1182938%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K148-Unsecurity%2Fmp%2F1182938%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%20class%3D%22%22%3E%3CSTRONG%20class%3D%22%22%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%8D%E7%84%B6%E8%83%BD%E5%A4%9F%E4%BD%BF%E7%94%A8%20PEmicro%2FOpenSDA%20%E9%A3%8E%E6%A0%BC%E7%9A%84%E6%B5%81%E7%A8%8B%E8%BF%9B%E8%A1%8C%E8%BF%9E%E6%8E%A5%EF%BC%9A%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%88%96%E8%AE%B8%E5%80%BC%E5%BE%97%E4%B8%80%E8%AF%95%EF%BC%8C%E5%9B%A0%E4%B8%BANXP%E6%8C%87%E5%87%BAPEmicro%E5%B7%A5%E5%85%B7%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E6%93%A6%E9%99%A4%E5%8A%9F%E8%83%BD%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E%E6%93%A6%E9%99%A4%E9%97%AA%E5%AD%98%E5%9D%97%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E8%80%8C%20J-Link%20%E4%BD%BF%E7%94%A8%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E%E6%89%B9%E9%87%8F%E6%93%A6%E9%99%A4%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%8A%A0%E8%BD%BD%E6%96%B0%E9%A1%B9%E7%9B%AE%E6%97%B6%EF%BC%9B%E5%BD%93%20CSEc%20%E9%98%BB%E6%AD%A2%E6%89%B9%E9%87%8F%E6%93%A6%E9%99%A4%E6%97%B6%EF%BC%8C%E8%BF%99%E7%A7%8D%E5%8C%BA%E5%88%AB%E5%8F%AF%E8%83%BD%E5%BE%88%E9%87%8D%E8%A6%81%E3%80%82%3C%2FLI%3E%0A%3CLI%20class%3D%22%22%3E%3CSTRONG%20class%3D%22%22%3E%E5%A6%82%E6%9E%9CRESET%E7%89%A9%E7%90%86%E4%BF%9D%E6%8C%81%E4%BD%8E%E7%94%B5%E5%B9%B3%EF%BC%9A%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%85%88%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E7%9B%AE%E6%A0%87%E5%8D%A1%E5%9C%A8RESET%E7%8A%B6%E6%80%81%E4%B9%9F%E5%8F%AF%E8%83%BD%E9%98%BB%E6%AD%A2%E6%A0%B8%E5%BF%83%E9%99%84%E5%8A%A0%EF%BC%8C%E4%BD%86%E6%97%A5%E5%BF%97%E4%B8%AD%E5%8F%8D%E5%A4%8D%E5%87%BA%E7%8E%B0%E7%9A%84%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%2F%E6%89%B9%E9%87%8F%E6%93%A6%E9%99%A4%E8%B6%85%E6%97%B6%E6%89%8D%E6%98%AF%E6%9B%B4%E6%9C%89%E5%8A%9B%E7%9A%84%E7%BA%BF%E7%B4%A2%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%20class%3D%22%22%3E%E6%80%BB%E4%B9%8B%EF%BC%9A%E8%BF%99%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%83%8F%E6%98%AF%E4%B8%80%E4%B8%AA%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%2FCSEc%2F%E6%89%B9%E9%87%8F%E6%93%A6%E9%99%A4%E9%98%BB%E6%AD%A2%E6%9D%A1%E4%BB%B6%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E8%BF%99%E4%B8%8D%E6%98%AF%E6%99%AE%E9%80%9A%E7%9A%84%E8%BF%9E%E6%8E%A5%E9%80%9F%E5%BA%A6%E9%97%AE%E9%A2%98%E3%80%82%E5%A6%82%E6%9E%9C%E5%90%AF%E7%94%A8%E4%BA%86%20CSEc%20%E5%B9%B6%E4%B8%94%E6%82%A8%E6%B2%A1%E6%9C%89%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3EMASTER_ECU_KEY%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E9%80%9A%E5%B8%B8%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E5%AE%9E%E9%99%85%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E6%98%AF%E6%9B%B4%E6%8D%A2MCU%E3%80%82%3C%2FP%3E%0A%3CP%20class%3D%22%22%3E%3CMARK%20class%3D%22bg-%5B%23FEE3A4%5D%20font-medium%22%3E%E5%86%B3%E5%AE%9A%E6%80%A7%E7%9A%84%E5%88%86%E6%94%AF%E5%9C%A8%E4%BA%8E%E6%98%AF%E5%90%A6%E5%90%AF%E7%94%A8%E4%BA%86%20CSEc%20%E5%88%86%E5%8C%BA%EF%BC%9A%E5%90%AF%E7%94%A8%E5%90%8E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3EMASTER_ECU_KEY%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E9%94%80%E6%AF%81%20CSEc%20%E5%88%86%E5%8C%BA%E5%B9%B6%E6%93%A6%E9%99%A4%EF%BC%9B%E6%B2%A1%E6%9C%89%E5%AE%83%EF%BC%8C%E5%8F%97%E4%BF%9D%E6%8A%A4%E7%9A%84%20S32K144%20%E5%8F%AF%E8%83%BD%E6%97%A0%E6%B3%95%E6%81%A2%E5%A4%8D%E3%80%82%3C%2FMARK%3E%3C%2FP%3E%0A%3CP%20class%3D%22%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20class%3D%22%22%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%3CBR%20%2F%3ERobin%3C%2FP%3E%3C%2FLINGO-BODY%3E
