NXP S32K118Q048 EVB LIN Stack
739件の閲覧回数
yousefdessouki123
I’m working with an NXP S32K118 EVB and trying to load a new LDF file into my LIN configuration. The stack worked fine with previous LDFs, but with the new file, I get terminal errors stating some nodes are missing configurable frames under Node Attributes. I also get a delay time too short error.
The same LDF works fine in CANoe without issues.
I have attached an example of error that I see in the terminal.
Issue: %error Error: xxxxx.ldf line: 111 "NodeName" Frame sporadic_frame_name- Missing frame in LDF Configurable frames in Node Attributes.
Level: Error
Type: Tool problem
Tool: Peripherals
Origin: Peripherals
Resource: Sources
Information: %error Error: xxxxx.ldf line: 111 "NodeName" Frame sporadic_frame_name- Missing frame in LDF Configurable frames in Node Attributes.
 I want to know what could be possibly causing these and how to fix them. Is it an issue in Design studio, an inherent limitation in the NXP LIN stack or  a problem in the file? Bear in mind, that the LIN stack is comptible with the RTD since I got one of the LIN stack examples working.
Any help would be appreciated.
regards,
709件の閲覧回数
danielmartynek
Hi @yousefdessouki123,
Can you share the LDF?
Which revision of the S32k1xx LIN Stack do you use?
Thank you,
BR, Daniel
%3CLINGO-SUB%20id%3D%22lingo-sub-2137593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENXP%20S32K118Q048%20EVB%20LIN%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20NXP%20S32K118%20EVB%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%20LDF%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%20LIN%20%E6%A7%8B%E6%88%90%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AF%E4%BB%A5%E5%89%8D%E3%81%AE%20LDF%20%E3%81%A7%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%8E%E3%83%BC%E3%83%89%E3%81%A7%E3%83%8E%E3%83%BC%E3%83%89%E5%B1%9E%E6%80%A7%E3%81%AE%E4%B8%8B%E3%81%AB%E6%A7%8B%E6%88%90%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%99%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%81%85%E5%BB%B6%E6%99%82%E9%96%93%E3%81%8C%E7%9F%AD%E3%81%99%E3%81%8E%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%82%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%90%8C%E3%81%98%20LDF%20%E3%81%AF%20CANoe%20%E3%81%A7%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E4%BE%8B%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%3A%20%25error%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20xxxxx.ldf%20%E8%A1%8C%3A%20111%20%22NodeName%22%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20sporadic_frame_name%20-%20LDF%20%E3%81%AB%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%8E%E3%83%BC%E3%83%89%E5%B1%9E%E6%80%A7%E3%81%AB%E6%A7%8B%E6%88%90%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AC%E3%83%99%E3%83%AB%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E%E3%82%BF%E3%82%A4%E3%83%97%3A%20%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E5%95%8F%E9%A1%8C%3CBR%20%2F%3E%E3%83%84%E3%83%BC%E3%83%AB%3A%20%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%3CBR%20%2F%3E%E8%B5%B7%E6%BA%90%3A%20%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%3CBR%20%2F%3E%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%3A%20%E3%82%BD%E3%83%BC%E3%82%B9%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20%25error%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20xxxxx.ldf%20%E8%A1%8C%3A%20111%20%22NodeName%22%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20sporadic_frame_name%20-%20LDF%20%E3%81%AB%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%8E%E3%83%BC%E3%83%89%E5%B1%9E%E6%80%A7%E3%81%AB%E6%A7%8B%E6%88%90%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%AF%E4%BD%95%E3%81%AA%E3%81%AE%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%9D%E3%82%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%AE%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%20Design%20Studio%20%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81NXP%20LIN%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AE%E5%9B%BA%E6%9C%89%E3%81%AE%E5%88%B6%E9%99%90%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%99%E3%81%8B%3FLIN%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AE%E4%BE%8B%E3%81%AE%201%20%E3%81%A4%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81LIN%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AF%20RTD%20%E3%81%A8%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E7%95%99%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20S32K118Q048%20EVB%20LIN%20Stack%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251159%22%20target%3D%22_blank%22%3E%40yousefdessouki123%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3ECAN%20LDF%E3%82%92%E5%85%B1%E6%9C%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3ES32k1xx%20LIN%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AE%E3%81%A9%E3%81%AE%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%E3%80%81%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E
