Hi team,
I am currently working on LPSPI communication on the S32K344 EVK using NXP RTD 4.0.0.
I have completed the required configuration for LPSPI and am trying to develop an SPI loopback communication on the EVK.
However, I am currently facing an issue where the data is being transmitted, but I am not receiving the expected data in the RX buffer.
I have attached the following for your reference:
- Project source code
- Relevant configuration details
Could you please go through the attached project and configuration and help me identify the issue?
Specifically, I would appreciate your support in checking:
- LPSPI master/slave configuration
- LPSPI pin configuration and signal routing
- TX/RX buffer configuration
- API usage for LPSPI transmit and receive
Any additional configuration required for loopback communication on the S32K344 EVK
Please let me know if any additional information or logs are required from my side.
Raky
