MCU LED is off
MCU LED is off
KangZiHao
When I use SIMULINK to generate code, the MCU LED of the EVB is off, and now the 3.3V power supply cannot be detected
lukaszadrapa
It would be nice to tell us which EVB you have, at least.
Anyway, if power supply doesn't work after that, there could be some shortcut caused by wrong configuration between GPIO and some external circuits.
Lukas
