MCSPTE1AK344 code generation
已解决
跳至解决方案
3,189 次查看
Albatros
I tried to generate the MCSPTE1AK344_PMSM_FOC_2Sh_as_tr code from S32DS peripherals and I can see that my motor is working properly in debug mode but when I am done with the debug mode my motor stops working. What causing this problem?
标记 (3)
1 解答
3,107 次查看
tomasfedor
I have 2 points:
1) verify steps from getting started  https://www.nxp.com/document/guide/get-started-with-the-mcspte1ak344-development-kit:GS-MCSPTE1AK344
and I also recommend S32K3 Motor Control Training. You can find there detailed explanation as well as hands on part starting at 33:00 https://www.nxp.com/design/training/s32k3-motor-control-training:TIP-S32K3-MOT-CNT
2) if fault appears you can clear the fault by pressings SW5 and SW6 simultaneously or you can clear fault using MCAT (see  "5. FreeMASTER and MCAT user interface" in AN13884 or AN13767).
details about the fault can be found in FreeMASTER tab "Faults & Trips"
Tomas Fedor
在原帖中查看解决方案
3 回复数
3,145 次查看
tomasfedor
if you want to leave debugging with running target I recommend to use
instead of
Tomas Fedor
3,135 次查看
Albatros
Okay, it worked, but when I reset my board, my motor was not working again. Do you have any other suggestions?
3,108 次查看
tomasfedor
I have 2 points:
Tomas Fedor
