MCAL-Generation Errors
2,979件の閲覧回数
gowthaman_krish
Dear All, I am facing some issue ,while generating MCAL Components . third party integration is done after that I am facing below issue. Kindly help me out how to solve the issue. ERROR 21-03-15,17:39:43 (1803) Invalid XPath-expression for Attribute "MIN" of node "/AUTOSAR/TOP-LEVEL-PACKAGES/ActiveEcuC/ELEMENTS/Gpt/GptHwConfiguration": (35020) Can not merge Ecu Resource properties for target "ARM" and derivate "S32K14X". Found duplicate property name "Icu.ChannelType.FTM_1_CH_7" in plugins: "Resource_TS_T40D2M10I1R0" , "Resource_TS_T40D2M10I3R0". ERROR 21-03-15,17:39:43 (1803) Invalid XPath-expression for Attribute "RANGE" of node "/AUTOSAR/TOP-LEVEL-PACKAGES/ActiveEcuC/ELEMENTS/Gpt/GptHwConfiguration/GptHwConfiguration_WdgInternal/GptIsrHwId": (35020) Can not merge Ecu Resource properties for target "ARM" and derivate "S32K14X". Found duplicate property name "Icu.ChannelType.FTM_1_CH_7" in plugins: "Resource_TS_T40D2M10I1R0" , "Resource_TS_T40D2M10I3R0". ERROR 21-03-15,17:39:43 (1803) Invalid XPath-expression for Attribute "RANGE" of node "/AUTOSAR/TOP-LEVEL-PACKAGES/ActiveEcuC/ELEMENTS/Gpt/GptHwConfiguration/GptHwConfiguration_36/GptIsrHwId": (35020) Can not merge Ecu Resource properties for target "ARM" and derivate "S32K14X". Found duplicate property name "Icu.ChannelType.FTM_1_CH_7" in plugins: "Resource_TS_T40D2M10I1R0" , "Resource_TS_T40D2M10I3R0". ERROR 21-03-15,17:39:43 (1803) Invalid XPath-expression for Attribute "RANGE" of node "/AUTOSAR/TOP-LEVEL-PACKAGES/ActiveEcuC/ELEMENTS/Gpt/GptHwConfiguration/GptHwConfiguration_0/GptIsrHwId": (35020) Can not merge Ecu Resource properties for target "ARM" and derivate "S32K14X". Found duplicate property name "Icu.ChannelType.FTM_1_CH_7" in plugins: "Resource_TS_T40D2M10I1R0" , "Resource_TS_T40D2M10I3R0". ERROR 21-03-15,17:39:43 (1803) Invalid XPath-expression for Attribute "RANGE" of node "/AUTOSAR/TOP-LEVEL-PACKAGES/ActiveEcuC/ELEMENTS/Gpt/GptHwConfiguration/GptHwConfiguration_1/GptIsrHwId": (35020) Can not merge Ecu Resource properties for target "ARM" and derivate "S32K14X". Found duplicate property name "Icu.ChannelType.FTM_1_CH_7" in plugins: "Resource_TS_T40D2M10I1R0" , "Resource_TS Best Reg, Gowtham K
2,955件の閲覧回数
hungnguyenphi
Hello @gowthaman_krish ,
Could you please check if you have added 2 resource module in the project?
Hung
