Logging ASM330LHH IMU Data to W25Q64JV External Flash Using S32K344
72件の閲覧回数
sharathkumar2026
HI team
I am working on an implementation where the ASM330LHH IMU sensor is interfaced with the S32K344 MCU, and the acquired sensor data (for example, accelerometer and gyroscope measurements) must be stored in a W25Q64JVSSIQ external QSPI Flash memory using S32 Design Studio (S32DS) 3.6.8.
Currently, I am facing challenges in integrating the IMU data acquisition with the external Flash storage mechanism.
I would appreciate guidance on the following topics:
1. External Flash (W25Q64JV) Enablement Through QSPI
  • What are the recommended steps to configure the QuadSPI (QSPI) peripheral in S32K344 for interfacing with the W25Q64JV external Flash?
  • I have already QSPI RTD drivers and configuration modules should be used in S32DS 3.6.8
  • How can the QSPI communication be validated after initialization?
  • What is the recommended procedure to read the JEDEC ID and verify that the external Flash is detected correctly?
2. Integration of ASM330LHH Sensor Data with External Flash Storage
  • What is the recommended software architecture for integrating the ASM330LHH sensor driver with the W25Q64JV Flash driver?
  • What sequence should be followed to:
    1. Initialize the IMU sensor.
    2. Acquire accelerometer/gyroscope data.
    3. Buffer the sensor samples in RAM.
    4. Program the buffered data into external Flash memory.
  • Are there any best practices for implementing page-aligned Flash writes, sector erase management, and circular logging mechanisms?
  • How should timestamps and sensor records be organized to support efficient data retrieval?
3. Verification and Validation of Stored Data
  • What is the recommended approach to verify that the IMU data stored in external Flash matches the originally acquired sensor data?
  • Should read-back verification be performed after every page program operation?
  • What validation methods are commonly used to ensure data integrity, such as:
    • Flash read/write verification
    • Checksum or CRC validation
    • Memory dump analysis
    • UART/CAN diagnostic logging
  • How can the stored accelerometer and gyroscope data be compared against real-time sensor readings to confirm correctness?
  1.
タグ(1)
32件の閲覧回数
Julián_AragónM
Hello @sharathkumar2026,
1. There is an already existing example for communicating with the on-board W25Q64 Winbond memory for the FRDM-A-S32K344 board in our Application Code Hub: QSPI Flash Memory Read/Write demo for FRDM-A-S32K344.
The example performs a device identification via JEDEC ID and status register readout, a continuous sector erase, page write, read-back, and data integrity verification, with RGB LED feedback via GPIO to indicate operation progress and pass/fail status.
You can import it directly through S32DS:
2. The ASM330LHH is a third-party device, so you must look for its datasheet, or user manual in order to know which commands to send and how to read the data.
I can recommend going over the Motion Sensing using FreeMASTER example. It reads 3-axis acceleration data from an FXLS8964AF accelerometer over LPI2C: It is based on S32K312, and uses FreeMASTER, however, it may prove useful to use it as reference.
3. This depends on the level of robustness your application needs. Read-back verification is usually not needed, simply check returned status after every operation and validate each record with CRC.
Julián
%3CLINGO-SUB%20id%3D%22lingo-sub-2420566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K344%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6ASM330LHH%20IMU%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92W25Q64JV%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E8%A8%98%E9%8C%B2%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2420566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3EHI%E3%83%81%E3%83%BC%E3%83%A0%3C%2FSTRONG%3E%3C%2FP%3E%3CDIV%3E%3CP%3E%E7%A7%81%E3%81%AF%3CSTRONG%3EASM330LHH%20IMU%E3%82%BB%E3%83%B3%E3%82%B5%3C%2FSTRONG%3E%E3%82%92%3CSTRONG%3ES32K344%20MCU%3C%2FSTRONG%3E%E3%81%A8%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%97%E3%80%81%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%87%E3%83%BC%E3%82%BF(%E4%BE%8B%E3%81%88%E3%81%B0%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%82%84%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%AE%E6%B8%AC%E5%AE%9A%E5%80%A4)%E3%82%92%3CSTRONG%3ES32%20Design%20Studio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id%3D%22toc-hId--441223211%22%20id%3D%22toc-hId--441198285%22%3E1.%20QSPI%E3%82%92%E9%80%9A%E3%81%98%E3%81%9F%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5(W25Q64JV)%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%AB%E3%83%A1%E3%83%B3%E3%83%88%3C%2FH2%3E%3CUL%3E%3CLI%3ES32K344%E3%81%A7%20%3CSTRONG%3EQuadSPI(QSPI)%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%3C%2FSTRONG%3E%20%E3%82%92W25Q64JV%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A8%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AE%E6%8E%A8%E5%A5%A8%E6%89%8B%E9%A0%86%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3E%E3%81%99%E3%81%A7%E3%81%AB%20%3CSTRONG%3EQSPI%20%3C%2FSTRONG%3ERTD%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A8%E8%A8%AD%E5%AE%9A%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AFS32DS%203.6.8%E3%81%A7%E4%BD%BF%E3%81%86%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%3C%2FLI%3E%3CLI%3E%E5%88%9D%E6%9C%9F%E5%8C%96%E5%BE%8C%E3%81%ABQSPI%E9%80%9A%E4%BF%A1%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A4%9C%E8%A8%BC%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3EJEDEC%20ID%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%80%81%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%8E%A8%E5%A5%A8%E6%89%8B%E9%A0%86%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FLI%3E%3C%2FUL%3E%3CHR%20%2F%3E%3CH2%20id%3D%22toc-hId-2046289622%22%20id%3D%22toc-hId-2046314548%22%3E2.%20ASM330LHH%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%81%A8%E3%81%AE%E7%B5%B1%E5%90%88%3C%2FH2%3E%3CUL%3E%3CLI%3E%3CSTRONG%3EASM330LHH%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FSTRONG%3E%E3%81%A8%3CSTRONG%3EW25Q64JV%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FSTRONG%3E%E3%82%92%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%86%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3COL%3E%3CLI%3EIMU%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%2F%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%96%E5%BE%97%E3%80%82%3C%2FLI%3E%3CLI%3E%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92RAM%E3%81%AB%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLI%3E%3CLI%3E%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3C%2FLI%3E%3CLI%3E%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%9FFlash%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%E6%B6%88%E5%8E%BB%E3%83%9E%E3%83%8D%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%E3%80%81%E5%BE%AA%E7%92%B0%E3%83%AD%E3%82%B0%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%81%AE%E5%AE%9F%E8%A3%85%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%83%99%E3%82%B9%E3%83%88%E3%83%97%E3%83%A9%E3%82%AF%E3%83%86%E3%82%A3%E3%82%B9%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3E%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%97%E3%82%84%E3%82%BB%E3%83%B3%E3%82%B5%E8%A8%98%E9%8C%B2%E3%81%AF%E5%8A%B9%E7%8E%87%E7%9A%84%E3%81%AA%E3%83%87%E3%83%BC%E3%82%BF%E5%8F%96%E5%BE%97%E3%82%92%E6%94%AF%E6%8F%B4%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%95%B4%E7%90%86%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FLI%3E%3C%2FUL%3E%3CHR%20%2F%3E%3CH2%20id%3D%22toc-hId-238835159%22%20id%3D%22toc-hId-238860085%22%3E3.%20%E4%BF%9D%E5%AD%98%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E6%A4%9C%E8%A8%BC%E3%81%A8%E5%A6%A5%E5%BD%93%E6%80%A7%E7%A2%BA%E8%AA%8D%3C%2FH2%3E%3CUL%3E%3CLI%3E%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%9FIMU%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E5%85%83%E3%80%85%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%83%87%E3%83%BC%E3%82%BF%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FLI%3E%3CLI%3E%E3%83%9A%E3%83%BC%E3%82%B8%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AE%E5%90%84%E6%93%8D%E4%BD%9C%E5%BE%8C%E3%81%AB%E3%80%81%E8%AA%AD%E3%81%BF%E6%88%BB%E3%81%97%E6%A4%9C%E8%A8%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E5%AE%8C%E5%85%A8%E6%80%A7%E3%82%92%E7%A2%BA%E4%BF%9D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AB%E7%94%A8%E3%81%84%E3%82%89%E3%82%8C%E3%82%8B%E6%A4%9C%E8%A8%BC%E6%96%B9%E6%B3%95%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%3A%3CUL%3E%3CLI%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%E6%A4%9C%E8%A8%BC%3C%2FLI%3E%3CLI%3E%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%E3%81%BE%E3%81%9F%E3%81%AFCRC%E6%A4%9C%E8%A8%BC%3C%2FLI%3E%3CLI%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%80%E3%83%B3%E3%83%97%E5%88%86%E6%9E%90%3C%2FLI%3E%3CLI%3EUART%2FCAN%20%E8%A8%BA%E6%96%AD%E3%83%AD%E3%82%B0%E8%A8%98%E9%8C%B2%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%9F%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%82%84%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%80%A4%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E6%AD%A3%E7%A2%BA%E6%80%A7%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FLI%3E%3C%2FUL%3E%3CHR%20%2F%3E%3COL%3E%3CLI%3E%26nbsp%3B%3C%2FLI%3E%3C%2FOL%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2420786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Logging%20ASM330LHH%20IMU%20Data%20to%20W25Q64JV%20External%20Flash%20Using%20S32K344%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2420786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262397%22%20target%3D%22_blank%22%3E%40sharathkumar2026%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E1.FRDM-A-S32K344%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E6%90%AD%E8%BC%89%E3%81%AEW25Q64%20Winbond%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%A8%E3%81%AE%E9%80%9A%E4%BF%A1%E4%BE%8B%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%99%E3%81%A7%E3%81%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%83%8F%E3%83%96%E3%80%8C%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-appcodehub%2Fdm-qspi-read-write-s32k344%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%E3%83%87%E3%83%A2(FRDM-A-S32K344)%3C%2FA%3E%E3%80%8D%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81JEDEC%20ID%E3%81%A8%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%AA%AD%E3%81%BF%E5%87%BA%E3%81%97%E3%81%AB%E3%82%88%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E8%AD%98%E5%88%A5%E3%80%81%E9%80%A3%E7%B6%9A%E7%9A%84%E3%81%AA%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%E6%B6%88%E5%8E%BB%E3%80%81%E3%83%9A%E3%83%BC%E3%82%B8%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%80%81%E8%AA%AD%E3%81%BF%E6%88%BB%E3%81%97%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E6%95%B4%E5%90%88%E6%80%A7%E6%A4%9C%E8%A8%BC%E3%82%92%E8%A1%8C%E3%81%84%E3%80%81GPIO%E3%82%92%E7%B5%8C%E7%94%B1%E3%81%97%E3%81%9FRGBLED%E3%83%95%E3%82%A3%E3%83%BC%E3%83%89%E3%83%90%E3%83%83%E3%82%AF%E3%81%A7%E5%8B%95%E4%BD%9C%E9%80%B2%E8%A1%8C%E7%8A%B6%E6%B3%81%E3%82%84%E5%90%88%E6%A0%BC%2F%E5%A4%B1%E6%95%97%E7%8A%B6%E6%85%8B%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ES32DS%E3%81%8B%E3%82%89%E7%9B%B4%E6%8E%A5%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Julin_AragnM_0-1791907860554.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_0-1791907860554.png%22%20style%3D%22width%3A%20479px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397902i12607BBAE9E3AC66%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Julin_AragnM_0-1791907860554.png%22%20alt%3D%22Julin_AragnM_0-1791907860554.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E2.%20ASM330LHH%E3%81%AF%E3%82%B5%E3%83%BC%E3%83%89%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E8%A3%BD%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E3%81%A9%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E9%80%81%E3%82%8B%E3%81%8B%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E8%AA%AD%E3%81%BF%E6%96%B9%E3%82%92%E7%9F%A5%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%82%84%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%92%E6%8E%A2%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fappcodehub%3Fsearch%3Ddm-motion-sensing-frdm-a-s32k312-freemaster%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EFreeMASTER%E3%81%AE%E4%BE%8B%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%83%A2%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%B3%E3%82%B0%3C%2FA%3E%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%3C%2FSPAN%3E%3CSPAN%3ELPI2C%E4%B8%8A%E3%81%A7%3CSTRONG%3EFXLS8964AF%3C%2FSTRONG%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%8B%E3%82%893%E8%BB%B8%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%80%81S32K312%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%97%E3%81%A6FreeMASTER%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%8F%82%E8%80%83%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E3%81%86%E3%81%AE%E3%82%82%E6%9C%89%E7%94%A8%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E3.%20%E3%81%93%E3%82%8C%E3%81%AF%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%99%E3%82%8B%E5%A0%85%E7%89%A2%E6%80%A7%E3%81%AE%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AB%E3%82%88%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E8%AA%AD%E3%81%BF%E6%88%BB%E3%81%97%E6%A4%9C%E8%A8%BC%E3%81%AF%E9%80%9A%E5%B8%B8%E4%B8%8D%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E5%90%84%E6%93%8D%E4%BD%9C%E5%BE%8C%E3%81%AB%E8%BF%94%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81CRC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%90%84%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E5%8D%81%E5%88%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%82%B8%E3%83%A5%E3%83%AA%E3%82%A2%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
