LPSPI FRAMESZ and Receive Data Register
vusal
I'm interfacing S32K3xx with an external flash memory. This chip requires different size command and data combinations. For example, to read the status register one needs to send 1 byte command and wait for 1 byte of data to appear on the MISO line. Frame size can range from 8 bits to several bytes. Is there a way to interface this chip without needing changing FRAMESZ each time?
In the above example, I couldn't just send 1 byte of command. I had to send an extra dummy byte to allow for the memory chip to respond. So, my frame size had to be 16 bits long. I have other use cases where I am sending 1 byte of command + 3 bytes of address + 10 bytes of data (just an example). It seem like each time my data changes I have to modify the FRAMESZ.
Another question: It seem like to get correct data in the SPI data register I have to read that register each time I send out a frame. Is this how the SPI set up?
LPSPI1_transmit_16bits(tx_16bits); /* Transmit half word (16 bits) on LPSPI1 */
LPSPI1_16bits_read = LPSPI1_receive_16bits(); /* Receive half word on LSPI1 */
Thank you very much for your help!
Vusal
danielmartynek
Hello Vusal,
I understand you need to keep CS asserted throughout the whole 14-byte transfer (using the example, 1 byte of command + 3 bytes of address + 10 bytes of data).
For that, the LPSPI Continous mode can be used (TCR[CONT = 1]).
FRAMESZ can be set to 8bit frames.
The LPSPI will keep CS asserted until a new command with TCR[CONT = 0].
RTD LPSPI_IP driver
Call the function below with Length = 14.
danielmartynek
Hello Vusal,
RTD LPSPI_IP driver
vusal
Hi Daniel,
Thank you for your message. This fixed the issue.
One more quick question: It seem like to get correct data in the SPI data register I have to read that register each time I send out a frame. Is this how the SPI set up?
Thank you!
Best,
Vusal
danielmartynek
There is 4x32b RX FIFO disabled by default.
BR, Daniel
vusal
Thank you!
%3CLINGO-SUB%20id%3D%22lingo-sub-1887242%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPSPI%20FRAMESZ%20and%20Receive%20Data%20Register%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1887242%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3CBR%20%2F%3E%3CBR%20%2F%3EI'm%20interfacing%20S32K3xx%20with%20an%20external%20flash%20memory.%20This%20chip%20requires%20different%20size%20command%20and%20data%20combinations.%20For%20example%2C%20to%20read%20the%20status%20register%20one%20needs%20to%20send%201%20byte%20command%20and%20wait%20for%201%20byte%20of%20data%20to%20appear%20on%20the%20MISO%20line.%20Frame%20size%20can%20range%20from%208%20bits%20to%20several%20bytes.%20Is%20there%20a%20way%20to%20interface%20this%20chip%20without%20needing%20changing%20FRAMESZ%20each%20time%3F%3CBR%20%2F%3E%3CBR%20%2F%3EIn%20the%20above%20example%2C%20I%20couldn't%20just%20send%201%20byte%20of%20command.%20I%20had%20to%20send%20an%20extra%20dummy%20byte%20to%20allow%20for%20the%20memory%20chip%20to%20respond.%20So%2C%20my%20frame%20size%20had%20to%20be%2016%20bits%20long.%20I%20have%20other%20use%20cases%20where%20I%20am%20sending%201%20byte%20of%20command%20%2B%203%20bytes%20of%20address%20%2B%2010%20bytes%20of%20data%20(just%20an%20example).%20It%20seem%20like%20each%20time%20my%20data%20changes%20I%20have%20to%20modify%20the%20FRAMESZ.%3CBR%20%2F%3E%3CBR%20%2F%3EAnother%20question%3A%20It%20seem%20like%20to%20get%20correct%20data%20in%20the%20SPI%20data%20register%20I%20have%20to%20read%20that%20register%20each%20time%20I%20send%20out%20a%20frame.%20Is%20this%20how%20the%20SPI%20set%20up%3F%3CBR%20%2F%3E%3CBR%20%2F%3ELPSPI1_transmit_16bits(tx_16bits)%3B%20%2F*%20Transmit%20half%20word%20(16%20bits)%20on%20LPSPI1%20*%2F%3CBR%20%2F%3ELPSPI1_16bits_read%20%3D%20LPSPI1_receive_16bits()%3B%20%2F*%20Receive%20half%20word%20on%20LSPI1%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3EThank%20you%20very%20much%20for%20your%20help!%3CBR%20%2F%3E%3CBR%20%2F%3EVusal%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1889503%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPSPI%20FRAMESZ%20and%20Receive%20Data%20Register%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1889503%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThank%20you!%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1889421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPSPI%20FRAMESZ%20and%20Receive%20Data%20Register%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1889421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThere%20is%204x32b%20RX%20FIFO%20disabled%20by%20default.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielmartynek_0-1718707863682.png%22%20style%3D%22width%3A%20594px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1718707863682.png%22%20style%3D%22width%3A%20594px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F284644iB94C24F3224CEB0A%2Fimage-dimensions%2F594x180%3Fv%3Dv2%22%20width%3D%22594%22%20height%3D%22180%22%20role%3D%22button%22%20title%3D%22danielmartynek_0-1718707863682.png%22%20alt%3D%22danielmartynek_0-1718707863682.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1718707863682.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielmartynek_1-1718707956067.png%22%20style%3D%22width%3A%20591px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_1-1718707956067.png%22%20style%3D%22width%3A%20591px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F284646i79080B526FDCCE06%2Fimage-dimensions%2F591x68%3Fv%3Dv2%22%20width%3D%22591%22%20height%3D%2268%22%20role%3D%22button%22%20title%3D%22danielmartynek_1-1718707956067.png%22%20alt%3D%22danielmartynek_1-1718707956067.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_1-1718707956067.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%2C%20Daniel%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1888870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPSPI%20FRAMESZ%20and%20Receive%20Data%20Register%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1888870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Daniel%2C%3CBR%20%2F%3E%3CBR%20%2F%3EThank%20you%20for%20your%20message.%20This%20fixed%20the%20issue.%3CBR%20%2F%3E%3CBR%20%2F%3EOne%20more%20quick%20question%3A%26nbsp%3B%3CSPAN%3EIt%20seem%20like%20to%20get%20correct%20data%20in%20the%20SPI%20data%20register%20I%20have%20to%20read%20that%20register%20each%20time%20I%20send%20out%20a%20frame.%20Is%20this%20how%20the%20SPI%20set%20up%3F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3ELPSPI1_transmit_16bits(tx_16bits)%3B%20%2F*%20Transmit%20half%20word%20(16%20bits)%20on%20LPSPI1%20*%2F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3ELPSPI1_16bits_read%20%3D%20LPSPI1_receive_16bits()%3B%20%2F*%20Receive%20half%20word%20on%20LSPI1%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EThank%20you!%3CBR%20%2F%3E%3CBR%20%2F%3EBest%2C%3CBR%20%2F%3EVusal%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1887735%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPSPI%20FRAMESZ%20and%20Receive%20Data%20Register%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1887735%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Vusal%2C%3C%2FP%3E%0A%3CP%3EI%20understand%20you%20need%20to%20keep%20CS%20asserted%20throughout%20the%20whole%2014-byte%20transfer%20(using%20the%20example%2C%201%20byte%20of%20command%20%2B%203%20bytes%20of%20address%20%2B%2010%20bytes%20of%20data).%3C%2FP%3E%0A%3CP%3EFor%20that%2C%20the%20LPSPI%20Continous%20mode%20can%20be%20used%20(TCR%5BCONT%20%3D%201%5D).%3C%2FP%3E%0A%3CP%3EFRAMESZ%20can%20be%20set%20to%208bit%20frames.%3C%2FP%3E%0A%3CP%3EThe%20LPSPI%20will%20keep%20CS%20asserted%20until%20a%20new%20command%20with%20TCR%5BCONT%20%3D%200%5D.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERTD%20LPSPI_IP%20driver%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielmartynek_0-1718355095205.png%22%20style%3D%22width%3A%20638px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1718355095205.png%22%20style%3D%22width%3A%20638px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F284194iBA4B0C80A465C77F%2Fimage-dimensions%2F638x708%3Fv%3Dv2%22%20width%3D%22638%22%20height%3D%22708%22%20role%3D%22button%22%20title%3D%22danielmartynek_0-1718355095205.png%22%20alt%3D%22danielmartynek_0-1718355095205.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1718355095205.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ECall%20the%20function%20below%20with%20Length%20%3D%2014.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielmartynek_1-1718355278613.png%22%20style%3D%22width%3A%20779px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_1-1718355278613.png%22%20style%3D%22width%3A%20779px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F284195i92A88A113AEA4DDC%2Fimage-dimensions%2F779x123%3Fv%3Dv2%22%20width%3D%22779%22%20height%3D%22123%22%20role%3D%22button%22%20title%3D%22danielmartynek_1-1718355278613.png%22%20alt%3D%22danielmartynek_1-1718355278613.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_1-1718355278613.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
