LPI2C example non blocking
ソリューションへジャンプ
7,635件の閲覧回数
adrianwenger
i need a example for I2C master reqeuests data from a slave and waits to receive the data non blocking. The SDK only provides a example with blocking.
Adrian
6,950件の閲覧回数
danielmartynek
Attached is a simple bare-metal example with MPL3115A2 pressure/temperature sensor, although it is blocking example, it could help.
For non-blocking algorithm please refer to AN4803 I2C Non-Blocking Communication.
Attachment updated
7 返答(返信)
6,950件の閲覧回数
danielmartynek
Sorry for the late response.
The thing is that we don’t have such an example yet.
I have started working on an example with MPL3115A2 sensor,
but it is still in progress.
6,950件の閲覧回数
adrianwenger
Hello Daniel,
thanks i'm looking forward to your solution.
BR,
Adrian
6,950件の閲覧回数
danielmartynek
Attachment updated
6,950件の閲覧回数
rayray
Fresh Out Contributor
Hello Daniel,
I imported the example, changed the slave address, communicated with E2PROM,but can't work both write and read reg ,there is something wrong whit it?please help!
#define E2PROM_ADRR_R    0xA1
#define E2PROM_ADRR_W    0xA0
thanks
Ray
6,950件の閲覧回数
danielmartynek
What do you see on scope? It is transmitting something, do you get acknowledge?
6,950件の閲覧回数
rayray
Thanks very much,Reference the E2PROM datasheet changed something,now it works well
Ray
6,950件の閲覧回数
adrianwenger
