LPCMP WINDOW CONTROL
abunayeeem
I want to filter out certain portion of COUT_RAW output using window mode. How can i get control over rising and falling edge of the WINDOW??image.png
PetrS
window signal is selected by TRMUX module
So refer to S32K3xx_TRGMUX_connectivity.xlsx file attached to the device Reference Manual to know which signals/input sources can be selected and then program TRGMUX LPCMP_n register with desired value.
BR, Petr
