LIN conformance failed
shravani
When master send only header instead of header&Response frame type, at slave ECU Lin driver shall report LIN_ERR_NO_RESP. But it reports LIN_ERR_RESP_STOPBIT error instead. Because of this issue, one of the Lin conformance test cases is getting failed.
This has been tested on below environment
S32K1, RTD: 1.0.1, AUTOSAR: 4.4
S32K3, RTD 2.0.3, AUTOSAR: 4.4
Please refer following snap from function "Lin_Ipw_Callback"
