LIN Example S32K344 questions
ソリューションへジャンプ
4,549件の閲覧回数
nxp_user001123
Situation is as the following:
-> currently using : S32K3X4EVB-T172 evaluation board
-> installed S32DS, SDK, LIN Stack, RTD, ...
Then I want to use the LIN_Master example "Lin_Master_S32K344_Example_DS" and configured my board with S32DS but at compiling the project, it is missing the following files:
"lin_stack_cfg.h"
 "lin_common_api.h"
"lin_commontl_api.h"
"lin_diagnostic_service.h"
Do you have any idea where the files come from? Are they generated out from a .ldf file (in S32DS?)
Thanks in advance.
4,408件の閲覧回数
PetrS
PMC is configured in
With above setting I was able to pass outlined code when set VDD_HV_A to 3.3V using J18.2-3 jumper setting.
Or if V15_MCU is sourced from ballast transistor using J31.2-3.
BR, Petr
7 返答(返信)
4,431件の閲覧回数
nxp_user001123
Hello All,
So finally we can build the LIN example. The next problem is that the MCU is not getting over a generated/configured function in the file : "Power_Ip_PMC.c" in function "Power_Ip_PMC_PowerInit" exactly in this piece of code (highlighted line, line number 304):
If we go with debugger over the highlighted line , we are in some kind of deadlock/reset loop of the S32K3. Debugger is not working, we can not reset MCU. So we have to erease the whole memory of the chip with J-Flash Lite.
If we do this again with the debugger and just set "ConfigValue" (before execution in line 304) just to "0" we have a normal run.
Can anyone explain why? And where exactly we can find the configuration menu for this ConfigValue in S32DS? What is a optimal configuration for this register?
Thanks in advance.
4,409件の閲覧回数
PetrS
BR, Petr
4,383件の閲覧回数
nxp_user001123
Thanks a lot.
4,509件の閲覧回数
nxp_user001123
I tried to change the .mex file as you mentioned but I still got the same issue:
../src/main.c:30:10: fatal error: lin_stack_cfg.h: No such file or directory
   30 | #include "lin_stack_cfg.h"
compilation terminated.
What I did:
- Deleted old LIN example
- Opened LIN example again (with S32DS)
- Closed S32DS
- Changed mex file as you mentioned
- Opened S32DS
- Clicked on LIN example / Opened Configuration Tools
- Switched to my Package S32K344_172HDQFP
- Updated Code
--> Then I tried to build the whole project, where I got the error from above.
4,520件の閲覧回数
nxp_user001123
Hi Petr,
Thanks a lot I will try. Can you help me where I can get the LinStack user manual? I just found LPUART and LIN with RTD - Training...
4,514件の閲覧回数
PetrS
it is part of linstack installation. On my RTD4.0.0 and linstack 2.0.4
c:\NXP\S32DS.3.5_RTD400\S32DS\software\PlatformSDK_S32K3\stacks\lin\documentation\LIN_UserManual.pdf
BR, Petr
4,525件の閲覧回数
PetrS
I was able to built example following below steps.
-just open/create example
-modify mex file in external editor before opening in S32DS, search for src\LIN21.ldf and change it to src/LIN21.ldf
- do a code update and allow changes for generated LinIf.h and LInIf.c as described in LINStack user manual chapter 6 Known issues and limitations
Then project can be built and elf generated
BR, Petr
%3CLINGO-SUB%20id%3D%22lingo-sub-1980886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELIN%20%E8%B3%AA%E5%95%8FS32K344%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E7%8A%B6%E6%B3%81%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E2%97%8F%E7%8F%BE%E5%9C%A8%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%26gt%3B%3AS32K3X4EVB-T172%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%E2%97%8FS32DS%E3%80%81SDK%E3%80%81LIN%20Stack%E3%80%81RTD%E3%81%AA%E3%81%A9%E3%82%92%26gt%3B%E6%90%AD%E8%BC%89%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81LIN_Master%E4%BE%8B%E3%80%8CLin_Master_S32K344_Example_DS%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92S32DS%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%99%82%E3%81%AB%E6%AC%A1%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%8Clin_stack_cfg.h%E3%80%8D%3CBR%20%2F%3E%E3%80%8Clin_common_api.h%E3%80%8D%3CBR%20%2F%3E%E3%80%8Clin_commontl_api.h%E3%80%8D%3CBR%20%2F%3E%E3%80%8Clin_diagnostic_service.h%E3%80%8D%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%A9%E3%81%93%E3%81%8B%E3%82%89%E6%9D%A5%E3%81%9F%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AF.ldf%E3%81%8B%E3%82%89%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB(S32DS%E5%86%85%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1986907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ALIN%E3%81%AE%E4%BE%8BS32K344%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1986907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1984734%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ALIN%E3%81%AE%E4%BE%8BS32K344%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1984734%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EPMC%20%E3%81%AF%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22PetrS_0-1730289979009.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PetrS_0-1730289979009.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F307688iB49E8064D1D4DFAA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22PetrS_0-1730289979009.png%22%20alt%3D%22PetrS_0-1730289979009.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPetrS_0-1730289979009.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%AF%E3%80%81J18.2-3%20%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E8%A8%AD%E5%AE%9A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20VDD_HV_A%20%E3%82%92%203.3V%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81%E3%82%A2%E3%82%A6%E3%83%88%E3%83%A9%E3%82%A4%E3%83%B3%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%B8%A1%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81V15_MCU%E3%81%8CJ31.2-3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%90%E3%83%A9%E3%82%B9%E3%83%88%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8B%E3%82%89%E4%BE%9B%E7%B5%A6%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%2C%20Petr%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1983589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ALIN%E3%81%AE%E4%BE%8BS32K344%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1983589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%80%81%E3%81%A4%E3%81%84%E3%81%ABLIN%E3%81%AE%E4%BE%8B%E3%82%92%E4%BD%9C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81MCU%E3%81%8C%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%E3%81%AE%E7%94%9F%E6%88%90%2F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E9%96%A2%E6%95%B0%E3%82%92%E4%B9%97%E3%82%8A%E8%B6%8A%E3%81%88%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%3A%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E6%AD%A3%E7%A2%BA%E3%81%AB%E9%96%A2%E6%95%B0%E3%80%8CPower_Ip_PMC_PowerInit%E3%80%8D%E3%81%AE%E3%80%8CPower_Ip_PMC.c%E3%80%8D%EF%BC%88%E5%BC%B7%E8%AA%BF%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9F%E8%A1%8C%E3%80%81%E8%A1%8C%E7%95%AA%E5%8F%B7304%EF%BC%89%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202024-10-29%20085741.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202024-10-29%20085741.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F307414i095D49A1E4B9F3C3%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202024-10-29%20085741.jpg%22%20alt%3D%22Screenshot%202024-10-29%20085741.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%202024-10-29%20085741.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%BC%B7%E8%AA%BF%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9F%E8%A1%8C%E3%81%A7%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81S32K3%E3%81%AE%E3%81%82%E3%82%8B%E7%A8%AE%E3%81%AE%E3%83%87%E3%83%83%E3%83%89%E3%83%AD%E3%83%83%E3%82%AF%2F%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E9%99%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%83%9E%E3%82%A4%E3%82%B3%E3%83%B3%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81J-Flash%20Lite%E3%81%A7%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E5%85%A8%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%81%A7%E3%81%93%E3%82%8C%E3%82%92%E5%86%8D%E5%BA%A6%E8%A1%8C%E3%81%84%E3%80%81%22ConfigValue%22(304%E8%A1%8C%E7%9B%AE%E3%81%AE%E5%AE%9F%E8%A1%8C%E5%89%8D)%E3%82%92%E5%8D%98%E3%81%AB%20%220%22%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%AA%B0%E3%81%8B%E3%81%8C%E7%90%86%E7%94%B1%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%BE%E3%81%9F%E3%80%81S32DS%E3%81%AE%E3%81%93%E3%81%AEConfigValue%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%81%AF%E6%AD%A3%E7%A2%BA%E3%81%AB%E3%81%A9%E3%81%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%93%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E6%9C%80%E9%81%A9%E3%81%AA%E6%A7%8B%E6%88%90%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1981177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ALIN%E3%81%AE%E4%BE%8BS32K344%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1981177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E.mex%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E8%A8%80%E3%81%A3%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%A0%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E..%2Fsrc%2Fmain.c%3A30%3A10%3A%20fatal%20error%3A%20lin_stack_cfg.h%3A%20No%20such%20file%20or%20directory%0A%20%20%2030%20%7C%20%23include%20%22lin_stack_cfg.h%22%0A%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%5E~~~~~~~~~~~~~~~~%0Acompilation%20terminated.%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%8C%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%3A%3C%2FP%3E%3CP%3E-%20%E5%8F%A4%E3%81%84LIN%E3%81%AE%E4%BE%8B%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E-%20LIN%E3%81%AE%E4%BE%8B%E3%82%92%E5%86%8D%E5%BA%A6%E9%96%8B%E3%81%8F(S32DS%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FP%3E%3CP%3E-%20%E3%82%AF%E3%83%AD%E3%83%BC%E3%82%BA%E3%83%89S32DS%3C%2FP%3E%3CP%3E-%20%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%9F%E3%82%88%E3%81%86%E3%81%ABmex%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E-%20S32DS%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%3C%2FP%3E%3CP%3E-%20LIN%E3%81%AE%E4%BE%8B%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%20%2F%20%E9%96%8B%E3%81%84%E3%81%9F%E8%A8%AD%E5%AE%9A%E3%83%84%E3%83%BC%E3%83%AB%3C%2FP%3E%3CP%3E-%20%E3%83%9E%E3%82%A4%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8S32K344_172HDQFP%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E-%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E6%9B%B4%E6%96%B0%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E--%26gt%3B%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E5%85%A8%E4%BD%93%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%B8%8A%E3%81%8B%E3%82%89%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1981174%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ALIN%E3%81%AE%E4%BE%8BS32K344%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1981174%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%20LinStack%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%AERTD4.0.0%E3%81%A8linstack2.0.4%E3%81%A7%3CBR%20%2F%3Ec%3A%5C%20NXP%20%5C%20S32DS.3.5_RTD400%20%5C%20S32DS%20%5C%20software%20%5C%20%2F%20PlatformSDK_S32K3%20%5C%20stacks%20%5C%20lin%20%5C%20documentation%20%5C%20LIN_UserManual.pdf%3C%2FP%3E%0A%3CP%3EBR%2C%20Petr%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1981173%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ALIN%E3%81%AE%E4%BE%8BS32K344%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1981173%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Petr%2C%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E7%A7%81%E3%81%AF%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82LinStack%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AF%E3%81%A1%E3%82%87%E3%81%86%E3%81%A9RTD%E3%81%A8LPUART%E3%81%A8LIN%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0...%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1981143%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ALIN%E3%81%AE%E4%BE%8BS32K344%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1981143%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E4%BE%8B%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E-%E4%BE%8B%E3%82%92%E9%96%8B%E3%81%8F%2F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E-S32DS%E3%81%A7%E9%96%8B%E3%81%8F%E5%89%8D%E3%81%AB%E5%A4%96%E9%83%A8%E3%82%A8%E3%83%87%E3%82%A3%E3%82%BF%E3%81%A7mex%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%80%81src%5CLIN21.ldf%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%A6src%20%2F%20LIN21.ldf%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E-%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%80%81%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20LinIf.h%20%E3%81%A8%20LInIf.c%20%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E8%A8%B1%E5%8F%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81LINStack%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AE%E7%AC%AC%206%20%E7%AB%A0%20%E6%97%A2%E7%9F%A5%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A8%E5%88%B6%E9%99%90%E4%BA%8B%E9%A0%85%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%20elf%20%E3%82%92%E7%94%9F%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%2C%20Petr%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
