LCU out PWM
LCU out PWM
5,439 次查看
zeyu__1
I would like to know how to generate the application in this reference document through LCU components or have routines implemented through API functions in SDK. Thank you very much for your help!
5 回复数
5,418 次查看
Senlent
Hi@zeyu__1
attached is a bried routine I wrote when testing LCU and eMIOS module.
The LCU module is used to realize the output of complementary PWM with insert dead time.
If you want to have a deeper understanding of its implementation process, the following information will be very helpful to you.
https://www.nxp.com/design/development-boards/automotive-motor-control-solutions/s32k344-brushless-d...
5,407 次查看
zeyu__1
Hi@Senlent
Thank you very much for sharing, I am trying to replicate your routine,I want to drive the stepper motor driver through a PWM,Can you provide some thoughts on the unintended effects of my one-way PWM using only LCU out
5,400 次查看
Senlent
Hi@zeyu__1
The routine I provide you is already the simplest one.
eMIOS.ch1->TRGMUX->LCU0.0->Pair PWM with Dead time.
5,387 次查看
zeyu__1
Hi@Senlent
I understand the logic of what you said, based on which I would like to discuss something else with you,
For example, is it possible to write UCDIS registers to enable and disable PWM output at will after initialization via this API function Emios_Pwm_Ip_SetChannelEnable (), and also, after the LCU initializes and sets the output, I mean after the hardware is connected and can output PWM, Is it possible to change the PWM duty cycle and period of eMIOS output through API functions to achieve more operations?
Thank you very much for your answer, and I look forward to your reply this time
5,379 次查看
Senlent
Hi@zeyu__1
yes, you can test the demo project that i have sent you.
