Issue in BCTU FIFO to DMA destination buffer readout
1,056 次查看
Abil
I am testing following configuration
Flexpwm trigger at 100us to BCTU list consist of 3 channels, ADC conversation data is stored in FIFO1 and then through DMA I am trying to read this.I can see DMA destination data is not updating ..is is stuck with constant value.
can you give reference for transferring BCTU FIFO data to DMa destination buffer.
Abil
1,028 次查看
Senlent
Hi@Abil
please take a look at this post by PetrS.
https://community.nxp.com/t5/S32K-Knowledge-Base/Example-S32K344-PIT-BTCU-parallel-ADC-FIFO-DMA-DS3-...
the difference here is using PITto trigger BCTU.
