Inquiry about multicore example projects for S32K344MINI-EVB
asdfghj
I am currently working with the S32K344MINI-EVB  and would like to learn multicore startup and basic multicore operation on this platform.
Are there any official multicore example projects available for the S32K344MINI-EVB?
If not, are there any generic S32K344 multicore examples that can be used as a reference?
If such examples are available, I would appreciate it if you could advise what configurations need to be modified to run them on the S32K344MINI-EVB.
Thank you
VaneB
Hi @asdfghj
Currently, there are no examples available for multicore implementation using the S32K344MINI-EVB. However, I have listed several links to example codes for S32K3 devices that may be useful. While not all examples are specifically intended for the S32K344 device, the functionality is generally consistent across all S32K3 devices unless otherwise noted in the Reference Manual.
Additionally, we provide examples of the Inter-Platform Communication Framework (IPCF), a subsystem that enables applications running on multiple homogeneous or heterogeneous processing cores to communicate over various transport interfaces.
BR, VaneB
VaneB
Hi @asdfghj
BR, VaneB
%3CLINGO-SUB%20id%3D%22lingo-sub-2288736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EInquiry%20about%20multicore%20example%20projects%20for%20S32K344MINI-EVB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2288736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EHello%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EI%20am%20currently%20working%20with%20the%20S32K344MINI-EVB%26nbsp%3B%20and%20would%20like%20to%20learn%20multicore%20startup%20and%20basic%20multicore%20operation%20on%20this%20platform.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EAre%20there%20any%20official%20multicore%20example%20projects%20available%20for%20the%20S32K344MINI-EVB%3F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EIf%20not%2C%20are%20there%20any%20generic%20S32K344%20multicore%20examples%20that%20can%20be%20used%20as%20a%20reference%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EIf%20such%20examples%20are%20available%2C%20I%20would%20appreciate%20it%20if%20you%20could%20advise%20what%20configurations%20need%20to%20be%20modified%20to%20run%20them%20on%20the%20S32K344MINI-EVB.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EThank%20you%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2288975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Inquiry%20about%20multicore%20example%20projects%20for%20S32K344MINI-EVB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2288975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258502%22%20target%3D%22_blank%22%3E%40leishuting%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ECurrently%2C%20there%20are%20no%20examples%20available%20for%20multicore%20implementation%20using%20the%20S32K344MINI-EVB.%20However%2C%20I%20have%20listed%20several%20links%20to%20example%20codes%20for%20S32K3%20devices%20that%20may%20be%20useful.%20While%20not%20all%20examples%20are%20specifically%20intended%20for%20the%20S32K344%20device%2C%20the%20functionality%20is%20generally%20consistent%20across%20all%20S32K3%20devices%20unless%20otherwise%20noted%20in%20the%20Reference%20Manual.%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K324-Multi-Core-Example-Project-based-on-Whiteboard%2Fm-p%2F1547771%22%20target%3D%22_blank%22%3ES32K324%20Multi-Core%20Example%20Project%20based%20on%20Whiteboard%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FExample-S32K344-decouple-RTD400-Ip-C40-DS35%2Fta-p%2F1866329%22%20target%3D%22_blank%22%3EExample_S32K344_decouple_RTD400_Ip_C40_DS35%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K358-Multicore-Start-CM7-2-from-CM7-0%2Fta-p%2F1923889%22%20target%3D%22_blank%22%3ES32K358%20Multicore%20Start%20CM7_2%20from%20CM7_0%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EAdditionally%2C%20we%20provide%20examples%20of%20the%20Inter-Platform%20Communication%20Framework%20(IPCF)%2C%20a%20subsystem%20that%20enables%20applications%20running%20on%20multiple%20homogeneous%20or%20heterogeneous%20processing%20cores%20to%20communicate%20over%20various%20transport%20interfaces.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%2C%20VaneB%3C%2FP%3E%3C%2FLINGO-BODY%3E
