Imported LIN master code for 32k from s32ds is not building
917件の閲覧回数
manjunathNN
Hello
Imported example Lin master code from s32 SDK.
I did not done any changes in project file.
But build is not passed, got errors mentioned below:
In file included from ../src/main.c:21:
C:/NXP/S32DS.3.5/S32DS/software/PlatformSDK_S32K1_S32M24/RTD/BaseNXP_TS_T40D2M20I0R0/include/Mcal.h:61:10: fatal error: Soc_Ips.h: No such file or directory
61 | #include "Soc_Ips.h"
compilation terminated.
make: *** [src/subdir.mk:20: src/main.o] Error 1
make: *** Waiting for unfinished jobs....
In file included from ../Project_Settings/Startup_Code/exceptions.c:37:
make: *** [Project_Settings/Startup_Code/subdir.mk:42: Project_Settings/Startup_Code/exceptions.o] Error 1
In file included from ../Project_Settings/Startup_Code/system.c:43:
make: *** [Project_Settings/Startup_Code/subdir.mk:42: Project_Settings/Startup_Code/system.o] Error 1
"make -j12 all" terminated with exit code 2. Build might be incomplete.
13:06:54 Build Failed. 7 errors, 0 warnings. (took 1s.48ms)
 Please let me know how to solve this errors.
Project:
Thank you.
3 返答(返信)
895件の閲覧回数
danielmartynek
Hi @manjunathNN,
DId you generate the RTD code:
Which version of the LIN Stack do you use?
859件の閲覧回数
manjunathNN
Now generated but still it showing some errors:
../stacks/lin/src/lin_commontl_proto.c: In function 'tl_put_raw':
../stacks/lin/src/lin_commontl_proto.c:1172:5: error: implicit declaration of function 'OsIf_SuspendAllInterrupts' [-Werror=implicit-function-declaration]
1172 | OsIf_SuspendAllInterrupts();
../stacks/lin/src/lin_commontl_proto.c:1241:5: error: implicit declaration of function 'OsIf_ResumeAllInterrupts' [-Werror=implicit-function-declaration]
1241 | OsIf_ResumeAllInterrupts();
Invoking: Standard S32DS C Compiler
arm-none-eabi-gcc "@stacks/lin/src/lin_common_api.args" -MMD -MP -MF"stacks/lin/src/lin_lin21_proto.d" -MT"stacks/lin/src/lin_lin21_proto.o" -o "stacks/lin/src/lin_lin21_proto.o" "../stacks/lin/src/lin_lin21_proto.c"
cc1.exe: some warnings being treated as errors
make: *** [stacks/lin/src/subdir.mk:36: stacks/lin/src/lin_commontl_proto.o] Error 1
Building file: ../stacks/lin/lin_dal/src/lin_dal.c
arm-none-eabi-gcc "@stacks/lin/lin_dal/src/lin_dal.args" -MMD -MP -MF"stacks/lin/lin_dal/src/lin_dal.d" -MT"stacks/lin/lin_dal/src/lin_dal.o" -o "stacks/lin/lin_dal/src/lin_dal.o" "../stacks/lin/lin_dal/src/lin_dal.c"
Finished building: ../stacks/lin/src/lin_lin21_proto.c
Finished building: ../stacks/lin/lin_dal/src/lin_dal.c
08:40:26 Build Failed. 4 errors, 0 warnings. (took 3s.292ms)
This is the path in SDK : PlatformSDK_S32K1_S32M24\stacks\lin\examples\S32K1\S32K144\Lin_Master_S32K144_Example_DS
I am using example LIN from S32DS.3.5 SDK.
812件の閲覧回数
danielmartynek
Hi @manjunathNN,
Which of these LIN stacks have you installed:
Refer to the release noted of the stack.
There is a compatible RTD revision specified.
The stack must be used only with this very RTD.
Also, it is not recommended to have other RTDs installed in the same IDE.
You can always install more S32DS IDEs if you need to have more RTDs for some reason.
Thank you,
BR, Daniel
%3CLINGO-SUB%20id%3D%22lingo-sub-2164100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Es32ds%E3%81%8B%E3%82%8932k%E3%81%AELIN%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%82%82%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3C%2FP%3E%3CP%3Es32%20SDK%20%E3%81%8B%E3%82%89%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20LIN%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%81%AF%E6%88%90%E5%8A%9F%E3%81%9B%E3%81%9A%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E..%2Fsrc%2Fmain.c%3A21%20%E3%81%8B%E3%82%89%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%3A%3CBR%20%2F%3EC%3A%2FNXP%2FS32DS.3.5%2FS32DS%2F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%2FPlatformSDK_S32K1_S32M24%2FRTD%2FBaseNXP_TS_T40D2M20I0R0%2Finclude%2FMcal.h%3A61%3A10%3A%20%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Soc_Ips.h%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E61%20%7C%20%23include%20%22Soc_Ips.h%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%A1%E3%82%A4%E3%82%AF%3A%20***%20%5Bsrc%2Fsubdir.mk%3A20%3A%5Bsrc%2Fmain.o%5D%E3%82%A8%E3%83%A9%E3%83%BC1%3CBR%20%2F%3E%20make%3A%20***%20%E6%9C%AA%E5%AE%8C%E4%BA%86%E3%81%AE%E3%82%B8%E3%83%A7%E3%83%96%E3%82%92%E5%BE%85%E6%A9%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99....%3CBR%20%2F%3E%20..%2FProject_Settings%2FStartup_Code%2Fexceptions.c%3A37%20%E3%81%8B%E3%82%89%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%3A%3CBR%20%2F%3E%20C%3A%2FNXP%2FS32DS.3.5%2FS32DS%2F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%2FPlatformSDK_S32K1_S32M24%2FRTD%2FBaseNXP_TS_T40D2M20I0R0%2Finclude%2FMcal.h%3A61%3A10%3A%20%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Soc_Ips.h%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E61%20%7C%20%23include%20%22Soc_Ips.h%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%A1%E3%82%A4%E3%82%AF%3A%20***%20%5BProject_Settings%2FStartup_Code%2Fsubdir.mk%3A42%3A%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E8%A8%AD%E5%AE%9A%2F%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%B3%E3%83%BC%E3%83%89%2F%E4%BE%8B%E5%A4%96.o%5D%E3%82%A8%E3%83%A9%E3%83%BC1%3CBR%20%2F%3E%20..%2FProject_Settings%2FStartup_Code%2Fsystem.c%3A43%20%E3%81%8B%E3%82%89%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%3A%3CBR%20%2F%3E%20C%3A%2FNXP%2FS32DS.3.5%2FS32DS%2F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%2FPlatformSDK_S32K1_S32M24%2FRTD%2FBaseNXP_TS_T40D2M20I0R0%2Finclude%2FMcal.h%3A61%3A10%3A%20%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Soc_Ips.h%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E61%20%7C%20%23include%20%22Soc_Ips.h%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%A1%E3%82%A4%E3%82%AF%3A%20***%20%5BProject_Settings%2FStartup_Code%2Fsubdir.mk%3A42%3A%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E8%A8%AD%E5%AE%9A%2F%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%B3%E3%83%BC%E3%83%89%2Fsystem.o%5D%E3%82%A8%E3%83%A9%E3%83%BC1%3CBR%20%2F%3E%20%E3%80%8Cmake%20-j12%20all%E3%80%8D%E3%81%AF%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%202%20%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E13%3A06%3A54%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC7%E4%BB%B6%E3%80%81%E8%AD%A6%E5%91%8A0%E4%BB%B6%E3%80%82%EF%BC%881%E7%A7%9248%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%89%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22manjunathNN_0-1757053370531.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22manjunathNN_0-1757053370531.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F355673iE07803BEA8499439%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22manjunathNN_0-1757053370531.png%22%20alt%3D%22manjunathNN_0-1757053370531.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2167733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Imported%20LIN%20master%20code%20for%2032k%20from%20s32ds%20is%20not%20building%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2167733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254448%22%20target%3D%22_blank%22%3E%40manjunathNN%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%20LIN%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AE%E3%81%86%E3%81%A1%E3%81%A9%E3%82%8C%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielmartynek_0-1757583316360.png%22%20style%3D%22width%3A%20566px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1757583316360.png%22%20style%3D%22width%3A%20566px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F356465i74524195D59AA269%2Fimage-dimensions%2F566x242%3Fv%3Dv2%22%20width%3D%22566%22%20height%3D%22242%22%20role%3D%22button%22%20title%3D%22danielmartynek_0-1757583316360.png%22%20alt%3D%22danielmartynek_0-1757583316360.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%20RTD%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%20RTD%20%E3%81%AE%E3%81%BF%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E5%90%8C%E3%81%98%20IDEs%20%E3%81%AB%E4%BB%96%E3%81%AE%20RTD%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E7%90%86%E7%94%B1%E3%81%A7%20RTD%20%E3%82%92%E3%81%95%E3%82%89%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%84%E3%81%A4%E3%81%A7%E3%82%82%20S32DS%20IDE%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%E3%80%81%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2166260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Imported%20LIN%20master%20code%20for%2032k%20from%20s32ds%20is%20not%20building%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2166260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%BE%E3%81%A0%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E..%2Fstacks%2Flin%2Fsrc%2Flin_commontl_proto.c%3A%E9%96%A2%E6%95%B0%20'tl_put_raw'%20%E5%86%85%3A%3CBR%20%2F%3E%20..%2Fstacks%2Flin%2Fsrc%2Flin_commontl_proto.c%3A1172%3A5%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E9%96%A2%E6%95%B0%20'OsIf_SuspendAllInterrupts'%20%E3%81%AE%E6%9A%97%E9%BB%99%E7%9A%84%E3%81%AA%E5%AE%A3%E8%A8%80%20%5B-Werror%3Dimplicit-function-declaration%5D%3CBR%20%2F%3E%201172%20%7C%20OsIf_SuspendAllInterrupts()%3B%3CBR%20%2F%3E%20%7C%20%5E~~~~~~~~~~~~~~~~~~~~~~~~%3CBR%20%2F%3E%20..%2Fstacks%2Flin%2Fsrc%2Flin_commontl_proto.c%3A1241%3A5%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E9%96%A2%E6%95%B0%20'OsIf_ResumeAllInterrupts'%20%E3%81%AE%E6%9A%97%E9%BB%99%E7%9A%84%E3%81%AA%E5%AE%A3%E8%A8%80%20%5B-Werror%3Dimplicit-function-declaration%5D%3CBR%20%2F%3E%201241%20%7C%20OsIf_ResumeAllInterrupts()%3B%3CBR%20%2F%3E%20%7C%20%5E~~~~~~~~~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%3A%20%E6%A8%99%E6%BA%96%20S32DS%20C%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40stacks%2Flin%2Fsrc%2Flin_common_api.args%22-MMD%20-MP%20-MF%22stacks%2Flin%2Fsrc%2Flin_lin21_proto.d%22-MT%22stacks%2Flin%2Fsrc%2Flin_lin21_proto.o%22-o%20%22stacks%2Flin%2Fsrc%2Flin_lin21_proto.o%22%E3%80%8C..%2Fstacks%2Flin%2Fsrc%2Flin_lin21_proto.c%E3%80%8D%3CBR%20%2F%3E%3CBR%20%2F%3Ecc1.exe%3A%20%E4%B8%80%E9%83%A8%E3%81%AE%E8%AD%A6%E5%91%8A%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E6%89%B1%E3%82%8F%E3%82%8C%E3%82%8B%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%A1%E3%82%A4%E3%82%AF%3A%20***%20%5Bstacks%2Flin%2Fsrc%2Fsubdir.mk%3A36%3A%20stacks%2Flin%2Fsrc%2Flin_commontl_proto.o%5D%E3%82%A8%E3%83%A9%E3%83%BC1%3CBR%20%2F%3E%20make%3A%20***%20%E6%9C%AA%E5%AE%8C%E4%BA%86%E3%81%AE%E3%82%B8%E3%83%A7%E3%83%96%E3%82%92%E5%BE%85%E6%A9%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99....%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2Fstacks%2FLIN%2FLIN_dal%2Fsrc%2FLIN_dal.c%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%3A%20%E6%A8%99%E6%BA%96%20S32DS%20C%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3EArm-none-eabi-gcc%20%22%40stacks%2FLIN%2FLIN_dal%2Fsrc%2FLIN_dal.args%22-MMD%20-MP%20-MF%22stacks%2Flin%2Flin_dal%2Fsrc%2Flin_dal.d%22-MT%22%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%2Flin%2Flin_dal%2Fsrc%2Flin_dal.o%22-o%20%22stacks%2Flin%2Flin_dal%2Fsrc%2Flin_dal.o%22%E3%80%8C..%2Fstacks%2Flin%2Flin_dal%2Fsrc%2Flin_dal.c%E3%80%8D%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20..%2Fstacks%2FLIN%2Fsrc%2FLIN_LIN21_proto.c%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20..%2Fstacks%2FLIN%2FLIN_dal%2Fsrc%2FLIN_dal.c%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E3%80%8Cmake%20-j12%20all%E3%80%8D%E3%81%AF%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%202%20%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%8C%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E08%3A40%3A26%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%204%20%E4%BB%B6%E3%80%81%E8%AD%A6%E5%91%8A%200%20%E4%BB%B6%E3%80%82%EF%BC%883%E7%A7%92292%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%89%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AF%20SDK%20%E5%86%85%E3%81%AE%E3%83%91%E3%82%B9%E3%81%A7%E3%81%99%3A%20PlatformSDK_S32K1_S32M24%5Cstacks%5CLIN%5Cexamples%5CS32K1%5CS32K144%5CLin_Master_S32K144_Example_DS%3CBR%20%2F%3E%20S32DS.3.5%20SDK%20%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20LIN%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2164222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Imported%20LIN%20master%20code%20for%2032k%20from%20s32ds%20is%20not%20building%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254448%22%20target%3D%22_blank%22%3E%40manjunathNN%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3ERTD%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielmartynek_0-1757060631309.png%22%20style%3D%22width%3A%20583px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1757060631309.png%22%20style%3D%22width%3A%20583px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F355705i2D0EABB5683DBD27%2Fimage-dimensions%2F583x95%3Fv%3Dv2%22%20width%3D%22583%22%20height%3D%2295%22%20role%3D%22button%22%20title%3D%22danielmartynek_0-1757060631309.png%22%20alt%3D%22danielmartynek_0-1757060631309.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielmartynek_1-1757060658374.png%22%20style%3D%22width%3A%20420px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_1-1757060658374.png%22%20style%3D%22width%3A%20420px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F355707i07E1A2EEA574D7EC%2Fimage-dimensions%2F420x87%3Fv%3Dv2%22%20width%3D%22420%22%20height%3D%2287%22%20role%3D%22button%22%20title%3D%22danielmartynek_1-1757060658374.png%22%20alt%3D%22danielmartynek_1-1757060658374.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%20LIN%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
