ISELED under FREERTOS
1,922件の閲覧回数
Mike565
Hello:
     I'm trying to run an iseled sample under freertos,but it can not work.I created only one task which controls one led, runs every 20ms.I checked the waveform and found that a piece of the waveform is missing,as attachment shows.The normal waveform is a sample without freertos runs the same task.Is there any suggestion about how to fix this problem?Or any sample code about iseled run under freertos?
タグ(1)
2 返答(返信)
1,912件の閲覧回数
Mike565
problem solved.iseled init error,lack of some paramenter.
1,905件の閲覧回数
Senlent
Hi@Mike565
         Okay, I will close this case.
BR!
     Jim.
