INSTRUCTION CYCLE CLOCK
hajianik
Senior Contributor I
HI my target is 32K148 ,
THIS IS A SIMPLE QUESTION THAT I HAVE NOT BEEN ABLE TO FIND THE ANSWER SEARCHING ALL SORT OF THE DOCUMENTS
IN MY PROJECT:
PLL CLK =160 MHZ
SYSTEM CLK (CORE) = 80MHZ
BUS CLK= 40MHZ
Which one of those is used to execute instruction in thumb mode?
"NOP" is a 1 cycle instruction, but what which clock is used to calculate the cycle?
I suspect it'd be the System clk.
would that be right?
danielmartynek
Hi [email protected],
Yes, it is the CORE_CLK/SYS_CLK.
BR, Daniel
