I want to implement real-time PWM duty cycle change with DMA, Is there any demo you can give me for
1,732件の閲覧回数
Zhuang
I have tried to configure myself, but have failed, NXP can give me some reference
11 返答(返信)
1,699件の閲覧回数
Senlent
Hi@Zhuang
you can refer to this article which is all i can find for your topic.
https://community.nxp.com/t5/S32K-Knowledge-Base/Example-S32K118-FTM-PWM-DMA-S32DS-2-2/ta-p/1342183
1,690件の閲覧回数
Zhuang
I tried to follow this routine, but in the process I ran into a problem: I was passing data through DMA 10 10 10 0. Here in the figure, it should be 0 but it appears 1, I do not know whether the DMA did not transmit the number or the PWM did not update, how to check this?
1,683件の閲覧回数
Senlent
Hi@zhuang
I don't know how you get the picture you provided and you can take a look at the chapter
1,678件の閲覧回数
Zhuang
This is my configuration
1,675件の閲覧回数
Senlent
HI@zhuang
This is no different from the demo configuration I provided to you.
I suggest you create a separate project to test this feature. You can add some flag bits for DMA transfer completion and PWM synchronization completion, and use a logic analyzer to analyze these timings.
1,621件の閲覧回数
Zhuang
Hi Senlent,
I want to confirm, how to confirm the completion of PWM synchronization?
1,610件の閲覧回数
Senlent
Hi@Zhuang
I read the relevant content, and there seems to be no flag bit when the hardware triggers synchronization completion.
1,606件の閲覧回数
Zhuang
In addition to increasing the flag bit after the completion of DMA transfer, what other feasible measures?
1,673件の閲覧回数
Zhuang
I have now made some DMA complete transfer flag, only the flag set will allow the next send.
Now I want to confirm, how to confirm the completion of PWM synchronization?
1,681件の閲覧回数
Zhuang
I use Init_trig (CNT set 0) to trigger FTM output waveform change, FTM has waveform change, CHF set, trigger DMA so.
1,730件の閲覧回数
Zhuang
I used an S32K148
