"Warning: stack pointer is set up with incorrect alignment: stack address = 0x6c1. I am unable to fix this error, as it indicates an issue with the PE MICRO DRIVER. When I debug, the program cannot be halted."
Hi @huytan
Stack address and stack size is defined in a linker file. Did you modify the default linker file? Could you share it?
Lukas
