How to use S32K144 D-Flash on S32DS?
Felix_ar
Hi Everyone
How to setup S32DS?
Let S32K144 D-flsah 0x10000000~0x1000FFFF when compiler finish will store in .s19 file.
Thanks.
lukaszadrapa
Hi @Felix_ar
you can follow this HOWTO document:
https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/HOWTO-Place-custom-data-into-flash-mem...
The only difference is that you will create the segment for data flash like this:
int_data_flash : ORIGIN = 0x10000000, LENGTH = 0x0000FFFF
And then:
.data_flash :
KEEP(*(.data_flash))
} > int_data_flash
And then in *.c file:
const int my_array[10] __attribute__((section (".data_flash"))) = {0,1,2,3,4,5,6,7,8,9};
Lukas
lukaszadrapa
Hi @Felix_ar
And then:
.data_flash :
} > int_data_flash
Lukas
Felix_ar
Hi Luksa
Thanks for your help.
