How to use Freemaster MDBT Simulink
2,029件の閲覧回数
ferminzafira
I recently bought a s32-k344EVB-Q172 board. I am trying to view the variables with freeemaster. At the time of detecting the board with the freemaster connection wizard, it cannot be found.
I have installed the Simulink MBTD library, the S32 IDE, S32 design studio and S32 design studio extensions, realtime drive for cortex-M and freemaster.
What should I do to be able to connect with her?
Thank you.
3 返答(返信)
1,992件の閲覧回数
ferminzafira
Do I need to change some jumper? Do I need to install some driver, for example open SDA?
1,981件の閲覧回数
petervlna
Please follow getting started guide to set it properly:
https://www.nxp.com/document/guide/getting-started-with-the-s32k3x4evb-q172-evaluation-board:GS-S32K...
Peter
2,009件の閲覧回数
petervlna
Not sure where is the issue from infomation you share. But make sure you have a look at Freemaster community, there is guidance how to make it work.
Basically you will need 2 things. SW with freemaster in micro and installed freemaster interface.
As you are most probably going to tune some motor control aplication you will also need MCAT plugin to freemaster.
https://www.nxp.com/design/design-center/software/development-software/motor-control-application-tun...
Peter
