How to solve this compile warning?
赵子成
Hi all,
I compile the S32DS project and encounter many these warnings:无标题.png
Can anyone tell me how to solve?
Thanks.
jorge_a_vazquez
Hi 赵子成
This project was not made from scratch, Did you rename the project or change something in the settings? Please check the post:
refresh policy problem S32K142 EVB
Please try this and tell me if it works.
TIC
赵子成
Hi Jorge Antonio Alcala Vazquez
Yes, I copy the project from other project.
I have try like "refresh policy problem S32K142 EVB" post, but it doesn't work.
I don't know why.
jorge_a_vazquez
Hi 赵子成
This is a naming problem, my recommendation is to create a new project and then copy and past the sources files to your new project, so you could keep the name that you need for your project and for the launch configuration.
Jorge Alcala
